Copiers
Problem for Sharp Copiers
Generic problem for all Sharp Copiers
How do i use this?
By lorij2161 on Apr 03, 2009
need operation manual for: electrostatic copying machine
brand: SHARP
model: SF-2414
serial: 86500168
Solution #1
posted on Sep 13, 2009
Not Rated)
goodgold
Rank: Wiz  Office Equipment  Expert
Rating: 84%, 151 votes
Sharp SF2414, Сode
CH If lit steadily, paper feed section cover is open or manual feed unit not installed properly. If flashing, developer seal still installed, or toner density sensor/main board problem. EE Sub code EU: undertoned. May be toner density sensor problem or developer unit problem. Sub code EL: Over toned. May be toner density sensor problem or developer unit problem. H2 Sub code 0: Fuser thermistor. H3 Sub code 0: Fuser temperature too high. H4 Sub code 0: Fuser temperature too low. L1 Scan problem. Sub code is 0, but there is no more detail. Could be no scan drive; scan did not leave home; scan did not return home; scan overloaded; mirror motor problem; scan cable came off. L3 Scan return problem. Sub code 0. Approximately same causes as L1 L4 Sub code 1: Main drive problem. Sensor, gear, motor. L5 Sub code 2: Lens drive, motor, sensor. L8 Sub code 1 Power frequency varies by more than 5 % or for more than 5 sec. Sub code 3: AE sensor problem. PC Key counter not installed. SPFJAM Document feeder problem. U2 Sub code 1: Main board EEPROM problem. Sub code 4: Memory problem. U5 Sub code 5: high temperature at exposure glass when using document feeder
Was this helpful?
Yes
No
Popular Solutions for Copiers
Questions and Unsolved Problems for Copiers
Answer
What do customers think of the the Toshiba e-studio 5520c, as we are considering buying one?
Answer
royal copy star Ri3530- how to use it as a scanner?
Answer
Need default passcode for canon iR 3025
Describe your Copiers problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Copier Experts
Top Copier & Fax Repairmen
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
