Acer Aspire 3000  PC Notebook
Problem for Acer Aspire 3000 (AS3004WLCI) PC Notebook
Replacing RAM chip in a acer aspire 3000
By oggie55 on Sep 02, 2007
having problems removing the cover that houses the memory chips. Have removed the 2 screws but the cover does not want to come off. can't find any lock/unlock lever.
Best Solution
posted on Oct 28, 2007
Very Helpful)
danwiltshire
Rank: Guide
Rating: 82%, 8 votes
i own an aspire 3000 which has been quite sluggish so i thought it was time for a RAM upgrade.
1. To get to the ram you will need to unscrew the 2 little screws which are located on the middle panel on the underside of the laptop.
2. Once the screws are totally unscrewed (they will stay in the panel) slide the entire panel foward to the front of the laptop as far as it will go this is normally about 2-3 millimeters.
3. Gently prise up the panel with a fingernail or flat headed screwdriver, then apply a modest bit of force to remove the entire cover. do not be scared to apply lots of force as this is the only way you will remove it.
4. Install the RAM module
5. slide the cover back on into position the same way you took it off and screw back on
Was this helpful?
Yes
No
Solution #2
posted on Sep 02, 2007
Helpful)
mikef
Rank: Master
Rating: 83%, 21 votes
I found the user manual at
http://www.synapsenow.com/synapse/data/7...
Page 63 of the acer user manual listed these steps for changing the memory:
"1 Turn off the computer, unplug the AC adaptor (if connected) and remove the battery pack. Then turn the computer over to access its base.
2 Remove the screws from the memory cover; then lift up and remove the memory cover.
3 (a) Insert the memory module diagonally into the slot, then (b) gently press it down until it clicks into place.
4 Replace the memory cover and secure it with the screw.
5 Reinstall the battery pack, and reconnect the AC adaptor.
6 Turn on the computer.
The computer automatically detects and reconfigures the total memory"
Was this helpful?
Yes
No
3 people thought this was helpful
Popular Solutions for Acer Aspire 3000 PC Notebook
Questions and Unsolved Problems for Acer Aspire 3000 PC Notebook
Do you recommend Acer Aspire 3000 (AS3004WLCI) PC Notebook?
Answer
Answer
My acer 3000 wont come on, but when i plug it in, and press the power button, the battery light... (More)
Answer
just go an acer trying to figure out how to set up the webcam
Answer
at start up message appears re consistency disc and fat32 file. appears to boot normally except that... (More)
Answer
When I open Internet - it will show modem operating, then it will say not operating and it... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Laptops Experts
Top Computer & Laptop Repairmen
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
