Sony DVP-NC600 Multi-disc DVD Player
Problem for Sony DVP-NC600 Multi-disc DVD Player
Won't Eject or play DVD...just reads E 27 00
By danielpetty on Apr 03, 2009
I loaded a DVD for my daughter and it just said E 27 00. and now it does nothing besides that code. when i turn it on it makes one clicking noise. and no grinding.
Same Problem
May 21, 2009
-   Won't eject disk, just gives message "E 27 00" then goes to Standby. Won't give our disk back. Opened case with screwdriver, removed disk which was thrown off into back of case. Disk table won't turn. Belt broken? Motor burned out? Don't know what to do.-   Guest
May 19, 2009
-   Same problem, Won't open, play or eject. Just says E 27 00 -   katart90
May 05, 2009
-   DVD won't open just reads e 27 00 and shuts off!-   docdave1
Best Solution
posted on Jun 05, 2009
Very Helpful)
john_mich501
Rank: Apprentice
Rating: 100%, 3 votes
The problem is likely to be a jammed disk. All you need to to do is remove the cover by removing the 7 screws locking it on. The jammed disk will most likely be located where the dvd is read, this can be tricky to remove so carefully remove a screw at a time from the disk positioner (device with white disk on it, not 5 disk tray) gently trying to remove the disk after each screw is removed. The fewer screws removed the better. Usually only the screw on the right side needs to be removed to give rome to remove the disk.
Was this helpful?
Yes
No
3 people thought this was helpful
Popular Solutions for Sony DVP-NC600 Multi-disc DVD
Questions and Unsolved Problems for Sony DVP-NC600 Multi-disc DVD
Do you recommend Sony DVP-NC600 Multi-disc DVD Player?
Answer
Answer
I have a sony DVP-nc600. I was playing it with all five discs and it was on shuffle. It was... (More)
Answer
Mainly with CDs (but will on DVDs) - it just plays and then (I think hits a read error) just gives... (More)
Answer
kiss my arss this siisue being posted twice ton & 3 times is not help anyone I have the 5... (More)
Answer
DVD Tray continues to spin and I receive the error code: E 27 00
Describe your DVD Players problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top DVD Player Experts
Top TV Repairmen
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
