Question about Toshiba Satellite M55-S135 Notebook
My laptop wont hibernate!
I close my laptop and normally it will go into hibernation and then when i open it. It wakes up. Here for the past few days whenever i close my laptop it goes to the screen perparing to hibernate.. with the blue screen and windows on it...and stays there..nothing happens and i have to hard restart my laptop..after it start its fine until i close my laptop to put it into hibernation. Ive tried manually putting it into hibernation but it does the same thing. Can anyone help me?
  • 20 Answers
Typically this indicates a problem with a particular piece of hardware or its driver that is not cooperating when windows tries to hibernate. Do you have anything new attached to the system? If so, try unplugging it, rebooting, and see if it cooperates then. Also, have you checked the windows event log to see if windows reports any particular errors when trying to hibernate?
Posted on Sep 02, 2007
SOURCE:
Hp550 computer not going to sleep mode properly
No matter which model of HP laptop you own, battery life is a big issue. Hibernation mode is designed to increase the battery life of your HP laptop by switching off the monitor, hard drive and other parts of the unit after they have been idle for a specific period of time. While hibernation mode works well most of the time, in some cases, your HP laptop may not wake from hibernation the way it should.
Docking Station Issues Many hibernation problems are caused not by the HP laptop itself but by the docking station to which it is attached. Some models of docking station interfere with the normal operation of the hibernation on the HP laptop. The easiest way to test this is to remove the laptop from the docking station and allow it to sit until hibernation begins. If hibernation mode works with the laptop undocked but not while docked, you know the problem lies with the docking station instead of the HP laptop. b> Remote Desktop Issues If you need to connect to your HP laptop from elsewhere, it is helpful to reset the power settings to the Always On mode before you leave your home or office. Many models of HP laptops do not wake properly from hibernation when users connect to them remotely using the remote desktop feature of Windows. When users connect with remote desktop, the program sends a signal to the remote computer that should wake it from hibernation and allow it to function normally. However, this process does not always work as intended with HP computers, so it helps to change the power settings to allow a seamless connection. Video Drivers Problems with HP laptop hibernation also can be caused by a corrupt or outdated video drive. HP laptops come with built-in video processors, and the drivers they use are installed during the initial setup of the unit. If there is a problem with that driver, HP releases an update, so if you see problems with hibernation, your first step should be to check for an updated video driver. b> External Keyboard and Mouse Sometimes the HP laptop does not respond properly and does not wake from hibernation when you use the built-in keyboard and touchpad mouse. The sensitivity of HP touchpads varies from model to model, and that sensitivity can be reduced over time. You can test for this problem by attaching an external keyboard and mouse to the laptop to determine whether that resolves the problem.
Feb 20, 2013 | Computers & Internet
I have set up the hibernation settings for when you close the lid but now it wiont come out of it when the lid is opened
Hit the space bar or enter key to wake it up. Maybe you have to pres the Power Button to wake it up.
Read the manual to see how to wake it up.
Get online and got to www.google.com In the google search box type: "Dell Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operating system when requested. Look for Manuals on the site and search them on hibernation.
Below is what your manual says to get out of hibernation you have to press the Power Button (very last paragraph at bottom).
Hibernate Mode Hibernate mode conserves power by copying system data to a reserved area on the hard drive and then completely turning off the computer. When the computer exits hibernate mode, it returns to the same operating state it was in before entering hibernate mode.
notice.gif NOTICE: You cannot remove devices or undock your computer while your computer is in hibernate mode. Your computer enters hibernate mode if the battery charge level becomes critically low.
To manually enter hibernate mode:
  • Press <Fn><F1>.
or
  • Click the Start button, click Turn off computer, press and hold <Shift>, and then click Hibernate.
or
  • Depending on how you set the power management options on the Advanced tab in the Power Options Properties window, use one of the following methods to enter hibernate mode:
    • Press the power button.
    • Close the display.
    • Press <Fn><Esc>.
note.gif NOTE: Some PC Cards may not operate correctly after the computer exits hibernate mode. Remove and reinsert the card, or simply restart (reboot) your computer. To exit hibernate mode, press the power button. The computer may take a short time to exit hibernate mode. You cannot make the computer exit hibernate mode by pressing a key or touching the touch pad or track stick. For more information on hibernate mode, see the documentation that came with your operating system.
May 14, 2012 | Dell Latitude D610 Notebook
My laptop keeps saying hibernating and i cannot get to menu screen.
Definition: Hibernate is another option for powering down your laptop. When you use Hibernate all data will be saved to the hard drive in a compressed form. Once you start up from Hibernate mode you will be able to work with the applications and documents you left open before putting the laptop into Hibernate.
Hibernate is best used to conserve laptop battery power when you will be away from the laptop for more than a few minutes. You can put your laptop into Hibernate overnight or when you will be away from it for a few hours. Examples: Rather than shutting down my laptop each night, I use Hibernate to help conserve battery power and enable me to access my open files quicker in the morning.
If you are not going to use your computer for a few hours, it is a good idea to put it to sleep (also known as mode) to save power. If you are not going to use the computer for more than a day, it is usually best to turn it off.
hope it helps.... please rate if you like my post...thanks
Jun 06, 2011 | Computers & Internet
How do I get my laptop out of hibernation?
right click desktop screensaver settings power settings or control panel.
Oct 24, 2010 | HP Pavilion dv5-1000us Notebook PC
Msi cr400 screen flicker problem
There is a big difference between hibernate and sleep mode. One will not wake just by opening the lid. You can get a full answer from this web site:
http://www.mydigitallife.info/2007/10/12/what-is-the-differences-between-sleep-standby-and-hibernate-in-vista/
I suggest visiting that site for a full explanation. It just might be the answer for which you are searching.
Good luck,
-a.
Jul 23, 2010 | Computers & Internet
I have a Thinkpad t60. For the past few days it won't go into hiberation when I close the lid. It just stays on and consumes the battery.
I have seen this issue before with my T60. It seemed to be related to not having restarted my laptop in a while. I used to use hibernate rather than shutting down my laptop for weeks at a time. Actually restarting my laptop seemed to get hibernate to work again.
In addition, you can check to see if for some reason the hibernate option has been disabled.
In Win XP (Win 7 is very similar):
  1. Click Start and select Control Panel.
  2. Double-click Power Options.
  3. On the Hibernate Tab, ensure Enable hibernation is selected (check mark).
  4. On the Advanced Tab, ensure that the setting for When I close the Lid is set to Hibernate (select it from the drop-down list if necessary). There should be an option for when plugged in and when on battery. Set both to your preference.
Hope this helps. Thanks for using FixYa.com
Jan 18, 2010 | Lenovo Thinkpad T60 Notebook
Blank screen
Turn Hibernate off for one thing. Hibernation leads to registry problems and boot issues. Go to control panel > power options > hibernate tab > uncheck the box. Reboot the machine. If you want, the laptop will go into standby mode after a period of time and will wake up with a touch on the touchpad. Go back to power options and there are settings in there that you can tailor to your liking.
Sep 30, 2009 | HP Pavilion dv2000t Notebook
Not waking from stand by on windows xp sp3
dont keep doing it, at some point your laptop wont ever comeback to life. so just use shutdown and hibernation
Mar 25, 2009 | HP Compaq nx7300 Notebook
Hibernation problem?
Press and hold the blue Fn key while pressig the F4
wait a moment and see if it wakes up
Nov 14, 2007 | IBM ThinkPad A31 Notebook
Toshiba Satellite M55-S135 Notebook Logo
192 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
