Question about IBM ThinkPad A31 Notebook
Thinkpad a31 lcd problems
I have a thinkpad a31 laptop that has a pink screen when it first boots up. I goes away in a few seconds once the screen warms up. I have a second thinkpad a31 with a good lcd screen. When i changed screens and turned on the laptop the ibm logo is huge and when it boots into windows xp it has a overlapping screen which i can't correct with a different resolution setting. I also changed the invertor board along with the lcd so they still match. I don't understand what is happening. Do these have to match the onboard video as well?
    Sergeant:
  • 457 Answers
Well yes BUT if it is a problem with the LCD then you would need to replace try plugging an external monitor to see if the sizes are normal if they arent then it is definately a problem with the screen resolutions.??
Posted on Sep 02, 2007
SOURCE:
Ibm thinkpad A31 Windows unable to start normally. Message on blue screen indicating "unmountable_boot_volume". Also got "Kernal_data_inpage_error" message. Does this indicate hard drive failure??
No, this is a known error within Windows. Read more information on it here: http://support.microsoft.com/kb/555302
But, if you are like me and don't like to read, just put your windows XP installation CD into the CD-ROM, boot up from the CD-ROM, DO NOT reinstall the operating system...just repair the installation and run "chkdsk /r".
Once that is done, restart the machine and it should boot up fine.
Jan 08, 2010 | IBM ThinkPad A31 Notebook
Laptop LCD goes black after a few seconds
Yes, The pink tint is an indication that the backlight is failing. Now the backlight is basically dead, the best way to get back going is to do an Ebay search for your model laptop and get a new screen. Most screens can be purchased for around $50.00 - $70.00 and they are very easy to swap. Email me if you need more info.
Buddy
Corporate Computer
www.ccl-la.com
Aug 03, 2009 | Samsung SyncMaster 940N Flat panel Monitor
Thinkpad A31 been unused for 12 months. Still appears to boot into windows, plenty of hard drive activity but no video displayed on screen at all, totally blank. I am pretty sure it boots fully into...
Sometimes I have seen something like this where there actually is a harddrive error, and it just acts like it books. It would be good to run a scan of the Hard drive. With something like GWScan. The Ultimate Boot CD would be able to run this for you.
Jun 16, 2009 | IBM ThinkPad A31 Notebook
Laptop LCD display problem
The backlight is the light bult that illuminates the screen. Before it finally goes out completely it will turn your screen a pink color on startup (and then usually become brighter and the pink fades). It is also possible that the backlight, also called a Cold Cathode Flourescent Light, CCFL, died an immediate death. But usually they take a while and signal with the "PINKNESS" first. If you found that your computer is working just fine connected to an external monitor (and you moved the base of your laptop around while connected to the monitor to be sure and left the computer on for a long time) then you have verified that the screen is the problem. It is usually two things: (1) the inverter, a circuit board that increases the voltage to supply the LCD which eats around 700 volts (yeah baby); or (2) the backlight itself. The first problem is a relatively easy and inexpensive fix. You can find how to replace an inverter by downloading the Hardware Maintenance Manual for the T40, T41, etc., from IBM/Lenovo's site. Replacing the backlight itself, a bulb that is like a strand of speghetti and even more delicate, is a tougher job. I would suggest purchasing a replacement screen in that event rather than replacing the backlight yourself. (The HMM probably does not show you how to replace the backlight/CCFL as it is a potentially dangerous job.) That suggestion assumes you can find a cost-effective replacement screen and do not mind opening the TP and putting the new screen in. At least look at the HMM to see what is involved. Good luck.
Apr 07, 2009 | IBM ThinkPad T42 Notebook
IBM A31 2652 Video garbled video at boot
This is very possibly a hardware problem, namely a crack in the motherboard. Sorry, no easy or cheap fix for it if that's the case.
Feb 18, 2009 | IBM ThinkPad T42 Notebook
update monitor driver
your screen may be going
how old is the system
Jan 26, 2009 | IBM ThinkPad A31 Notebook
Dell i6000 - Pink Screen
you are losing video from the motherboard..could be the video chip, yet this sort of thing can happen with laptops.
Feb 18, 2008 | Dell INSPIRON 6000 CENTRINO...
Disabled video card drivers for IBM ThinkPad A31 2652=Blank screen on reboot
hi, so far as i can understand ur question, u have disabled the video card in the device manager, if thats the case then post boot hit the F8 key which will take u to the startup menu, select safe mode with VGA option, then enable the vga card back and restart.. let me know
Nov 24, 2007 | IBM ThinkPad A31 Notebook
IBM ThinkPad A31 Notebook Logo
177 people viewed this question
Top IBM Computers & Internet Experts
Ekse
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
