Question about Whirlpool RF368 Electric Kitchen Range
Oven won't respond
My oven is sending me the message EO F2 and will not respond
  • dsichel Jul 18, 2008
    Lock icon is showing in display and will not clear. The oven is not locked, and because of this the oven will not heat. Unplugged it for awhile and still won't clear display.
  • Anonymous Mar 17, 2014
    CAN NOT USE OVEN
    President:
  • 878 Answers
Mandajo, the code is for a stuck or shorted keypad. Couple of things you can try. Press and hold the cancel/off key for 5 seconds. 2. Unplug the range for 1 minute. 3. In the back, disconnect the keypad ribbon cable from the main board. Clean the ends with an eraser and see if that cures the problem. If none of these work, looks like a new control is needed. Catriver.
Posted on Sep 02, 2007
EO F2 The oven will not start or stop. I can not get the oven to work but it will beep with this EO F2 message sometimes.
Hello Sonya,
The E0-F2 error code means that the oven temperature was higher than it's supposed to be. Usually the oven overheats because of a defective oven temperature sensor and the sensor should be checked. 11_3_2011_2_07_54_pm.jpgthis is what the sensor looks like...it is located within the oven chamber(usually in the left side) to check it,it needs to unplugged and using a mulitmeter set to measure ohms,check the sensor to be between 1060-1100 ohms at room temp. if the sensor is way lower/higher that 1060-1100 at room temp the sensor is bad and needs to be replaced, if the sensor is within that range then the control board is the problem.
GENE
Nov 03, 2011 | Whirlpool RBS275PD Electric Single Oven
After cooking my whirlpool Electric Range started to beep and shows EO F2. The range top is working ( and range top controls ) but the oven won't shut off and the controls are not working for the oven.
Here is what my online service manual for the F2-EO error code says
F2 - E0 Shorted keypad (also called touch pad) 1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock)
I hope this helps
Gene
Aug 01, 2011 | Whirlpool Kitchen Ranges
CONTINUE TO GET THIS ERROR MESSAGE EO-F2
you may have an oven temp sensor out of wack. may have carbon on it . wires going to it may have burned
Feb 03, 2010 | Kitchen Ranges
Electric kitchen aid double oven gives eo message
there should be more of a code like fo/eo or f2/eo or f3/eo or f5 /0o .. if you have # 1 = analog t digital l failure / replace control..= #2 shorted key pad / = replace control /? # 3 oven tempt sensor = repl oven sensor or fuse .// # 5 ck door /latch sw = replace component .. hope this helped . mm ( re/ck codes and see if one of thes matches your problem .. mm pls leave feed back ..
Dec 12, 2009 | Washing Machines
EO F2 Lock message on oven panel
The solution was to hold down the "start" button for five seconds, which reset the system. I figured out that I had entered the model number of my oven wrong (mistaking a "Z" for a "2"). When I re-entered the correct model number in the "search for manual" section of the Whirlpool site, I was able to access the user manual and find the section that walked me through the correction.
Dec 29, 2008 | Ovens
Message EO F2 on the panel
EO and F2 means you have a shorted keypad. Or the oven temp is too high. The cheapest route to go is to replace the oven temp sensor first. If you give me the model number i can get the part number. If the oven temp sensor doesnt fix the problem You have to replace the electronic control. Check to see if there is a y near the end of your model number. if there is then it is most likely just the sensor. If there is no y then it is most likely the electronic control. (this is what my code chart says) But you can try the oven temp sensor anyway. It may fix it.
Nov 21, 2008 | KitchenAid KERA205P Electric Kitchen Range
EO F2 code
THIS IS GENERALLY A BAD ELECTRONIC RANGE CONTROL OR ERC BOARD
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
Jun 01, 2008 | Kitchen Ranges
Error message on Whirlpool Gold gastop range: E0 -F2-
It means "shorted keypad".
1. Disconnect power from oven for longer than 30 seconds.
2. Re-apply power and observe for longer than 5 minutes.
3. If failure remains, disconnect power, replace control, then
go back to step 2.
4. Unplug and replug membrane connector.
Dec 29, 2007 | Whirlpool SB160PEE Gas Single Oven
Whirlpool RF368 Electric Kitchen Range Logo
133 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Ismael Rodriguez...
Sal De
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
