Question about Panasonic TH-42PD50U 42 in. Plasma EDTV
Tv My plasma tv comes on then turns off by itself. It only comes on for 5 secs?
I had the same problem with my new TH-50PX60B. I turned the tele on then after 5seconds it would switch off. The standby light would then blink on and off 11 times, pause for a second then flash 11 times. This would continue until the power wasturned off. Note the TV would not turn on for more than 5 seconds.
I solved this problem by turning the tele on and checking the fans at the back. My tele had 3 fans. If one of the fans is not turning, this will be the cause of the problem and the tele will shut down under the Emergency Shutdown System. To clear the fan try blowing on it to free up any dust etc. If that still doesn't work try using a thin instrument (tie wrap etc) to manually turn the fan and free it. Then power off the tele and turn it back on. The tv should work perfectly.
Posted on Oct 28, 2007
SOURCE:
Have a sanyo 50" plasma
This tv problems are related to powering up the tv and sustancening the tv power source to the tv itself.Replaced the tv sub power supply board where the a/c power cord plug into it.Try website like Ebay.com to buy a whole new refurbish sub power supply board for the replacement.
Sep 06, 2011 | Sanyo DP50747 50 in. Plasma TV
I bought a 52" plasma
you can try unplugging it for 10 secs, then plugged back in. Press and hold the menu button and minus volume button on the actual tv. While still holding those two buttons, press the power button. Continued to hold the menu and minus volume button for additional 3 secs. The tv should turn on in about 30 secs. If that does not work call customer care.
Jan 12, 2011 | Televison & Video
Philips flat screen 42" flashing red light 7 times it stops for 5 seconds and 7 more flashes if i unplug and plug it a few time it will come on
my 42 inch phillips, i turn it on green light comes on for 10 sec then red light comes on and flashes 4 times then stops for 5 sec then repeats.
Apr 20, 2010 | Philips 42PF9631D 42 in. Plasma Television
Tv turns itself off
At a guess, I would say no.
Your plasma TV likely uses an IR remote control, and although I have seen compatibility issues between IR remote devices, it is extremely rare.
The best way to test it is to remove the skybox and see if that solves the problem.
May 07, 2008 | Televison & Video
SVA Plasma - Turns off shortly after starting
Did you find out anything my SVA is doing the same thing. Thanks, Mark
Jun 02, 2007 | SVA-USA HD4208TIII-PDP 42 in. EDTV-Ready...
Panasonic TH-42PD50U 42 in. Plasma EDTV Logo
312 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
