Motorola Mobility MOTOKRZR K1 Cellular Phone Logo
Posted on Apr 03, 2009
My Phone Will not Stop inputting the Number ''8'' and it says ''external controls'' every time i turn it on, i can't control it. it keeps inputting the number 8 and says external controls are locked please help me asap!
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Apr 03, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
29
Points
Woah woah woah you mean to say that your phone controls you? Good luck with thaaat.
The keypad is probably stuck, what kind of phone do you have?
My Toshiba19LV610U keeps changing its input back to DVD
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/
tip
Caterpillar Fault Codes
CID code Name
1 Injector? 1
2 Injector, cylinder number 2
3 Injector number 3
4 Injector number 4
5 Injector, cylinder number 5
6 Injector, cylinder number 6
7 Injector number 7
8 Injector number 8
9 Injector number 9
10 Injector number 10
11 Injector number 11
12 Injector number 12
13 Injector number 13
14 Injector number 14
15 Injector number 15
16 Injector number 16
17 The fuel shut-off valve
18 The fuel control valve
19 Bypass valve accelerator
20 Device change timing of fuel injection
21 Position Sensor Engine
22 Sensor fuel injection advance
23 Drive Racks
24 position sensor rail
27 is a variable geometry turbocharger number 1
28 Drive with variable geometry turbocharger number 2
41 Power ECU (electronic control unit) 8 V DC
42 Valve inclusion nozzles
70 contact with the parking sensor
71 Timer stop idling
75 Oil temperature sensor circuit hydraulic steering system
The pressure sensor 81 at the inlet trap foreign particles
82 Pressure Sensor pnevmozapuska
84 speed sensor
91 Accelerator pedal position sensor
94 Pressure Sensor fuel pumping
95 The differential pressure sensor on the fuel filter
96 Fuel level sensor
98 Oil level sensor in the engine
99 The differential pressure sensor on the engine oil filter
100 Oil Pressure Switch Engine
101 pressure sensor crankcase gases
102 turbo pressure sensor
104 Oil pressure turbocharger
105 temperature sensor intake manifold
106 sensor input air pressure
Pressure sensor 109 of coolant downstream of the engine
110 Coolant Temperature Sensor Engine
111 level sensor, engine coolant
The differential pressure sensor 112 to filter engine coolant
124 gearbox oil level
126 differential pressure sensor on the oil filter transmission
127 Oil Pressure Switch gearbox
138 Mode Switch low traction
139 Solenoid tip ago
140 Solenoid tip forward
141 Eco Mode Switch
142 position sensor door to clean the radiator
143 contact pressure sensor control unit neutral
144 horn relay reverse
145 power supply circuit 12
146 Mode Switch hitch
147 pressure sensor lock-up clutch
148 pressure sensor in the hydraulic stroke
149 Three-way solenoid stabilization system of the implement when driving
150 Speed Sensor trambovatelya
151 Solenoid trambovatelya
152 diagnostic lamp control systems course
153 speed sensor right drive motor
154 RPM Sensor left actuator motor
155 solenoid switching stroke
156 Solenoid right turn in reverse (electronic display)
157 Solenoid left turn in reverse (electronic display)
158 Solenoid right turn forward direction (electronic display)
159 Solenoid left turn forward direction (electronic display)
160 Relay working equipment paver
161 brake sensor (chassis) pedal
162 Sensor Steering Wheel
The steering angle sensor 163 rotation
164 Pressure Sensor inclusion nozzles
167 Sensor charging voltage of the alternator
168 Electric system
171 of the ambient air temperature sensor
172 temperature sensor in the intake manifold
174 Fuel temperature sensor
175 Temperature Sensor Engine oil
177 oil temperature sensor Gearbox
190 RPM Sensor engine crankshaft
191 sensor output speed gearbox
248 data channel of Caterpillar
249 data channel J1922 SAE (Society of Automotive Engineers)
250 data channel J1708 / J1587 SAE (Society of Automotive Engineers)
Block 252 calibration
253 Personal chip control unit
254 electronic control unit
256 Map adjusting engine performance
257 Level detonation
258 sensor crank angle
259 set via software point fuel injection
260 oxygen sensor in the exhaust gas
261 the fuel injection timing calibration
262 circuit sensor supply 5 V
The power circuit 263 digital sensors (8 or 12)
264 pedal revolutions reduction
265 Input circuit stopping the engine, user-defined
266 Input circuit dry scroll engine (without fuel injection)
267 Chain input remote control signal Safe Stop engine
268 Error programmed parameter
269 circuit sensor supply
Code 270 cable computerized monitoring system (CMS)
271 Sound the alarm
272 sensor has exceeded the allowable turbo
273 pressure sensor at the outlet of the turbocharger
274 atmospheric pressure sensor
275 pressure sensor at the entrance of the right turbocharger
Pressure transducer 276 at the input of the left turbocharger
277 sensor calibration injection timing
278 The indicator light turn on the automatic control of engine speed (AESC)
279 coolant temperature in the intercooler front section
280 temperature sensor gear
281 The indicator light necessary Engine
282 Light indicator exceeding the permissible engine speed
283 Indicator Light air filter
284 Radio on EMS (electronic control system) (the signal of the engine)
285 overheating indicator light, engine coolant
286 Indicator light low oil pressure
287 Miniature digital output? 7
288 Miniature digital output? 8
289 Fuel pressure - before the fuel filter
290 pressure sensor in the pump drive engine cooling fan
The solenoid 291 engine cooling fan
292 solenoid hydraulic oil cooling fan
293 power analog output? 3
294 power analog output? 4
The control unit 295 hydraulic excavator heavy-duty
296 gearbox control unit
297 all-wheel drive system control
298 The probe brake pedal
299 position sensor gear lever
300 The primary windings of ignition coils
301 The primary winding of the ignition coil? 1
302 The primary winding of the ignition coil? 2
303 The primary winding of the ignition coil? 3
304 The primary winding of the ignition coil? 4
305 The primary winding of the ignition coil? 5
306 The primary winding of the ignition coil? 6
307 The primary winding of the ignition coil? 7
308 The primary winding of the ignition coil? 8
309 The primary winding of the ignition coil? 9
310 The primary winding of the ignition coil? 10
311 The primary winding of the ignition coil? 11
312 The primary winding of the ignition coil? 12
313 The primary winding of the ignition coil? 13
314 The primary winding of the ignition coil? 14
315 The primary winding of the ignition coil? 15
316 The primary winding of the ignition coil? 16
317 load cell
318 Right knock sensor
319 Left knock sensor
320 RPM Sensor / injection timing
321 Key switch reset / diagnostic confirmation
322 engine stop switch
323 The indicator light engine stop
324 Alarm lamp
325 detonation caused by the ignition system
Detonation System 326
327 Wrong number of knock sensors
328 Wrong number of cylinders of the engine
329 Error Link
330 Login with contact sensor propane content
331 Ignition Switch
332 keyboard switch
333 switch alarm
334 Reserve output
335 solenoid screw scraper
336 switch engine control
337 Remote Switch emergency stop
338 Relay pre-lube pump motor
339 contact pressure transducer pre-lube the engine
340 solenoid shut-off air
The solenoid 341? 4 warm-hydraulic distributor
342 Auxiliary speed sensor engine crankshaft
343 injector NOx catalyst in the exhaust gas
344 Relay injection pump converter of nitrogen oxides in exhaust gases
Pressure sensor 345 of the injection NOx catalyst in the exhaust gas
346 Relay stabilization system of the implement when driving
347 solenoid feed control (working volume) motor hydrostatic transmission
348 lock switch gearbox
Solenoid 349 gearbox synchronization
350 position sensor rod lift
351 position sensor rod misalignment
352 Sensor lift lever (in the cockpit)
353 sensor lever skew (in the cockpit)
The solenoid 354? 1 lift
The solenoid 355? 1 lowering
The solenoid 356? 1 unloading
357 Solenoid No. 1 return
358 Drive pressurization of the control loop hydraulic system work equipment
359 solenoid locking lifting
360 solenoid lock lowering
The electromagnet 361 tilt lock to download
362 solenoid control the fan speed of the engine
363 Drive stabilization system of the implement when driving
364 pressure sensor piston cavity lift cylinder
365 switch for limiter
366 contact gauge semiautomatic recess
367 Switch stabilization system of the implement when driving
368 switch, automatic / manual mode transmission
369 Login with shift indicator on the gearbox
370 Solenoid floating position arrows
Solenoid 371 beep
372 solenoid opening bucket (for excavator shovel)
373 solenoid closing bucket trucks through the hinged bottom (for excavator shovel)
374 Solenoid swing brake
375 Solenoid swing brake
376 Warning stroke
377-way solenoid brake
378 solenoid automatic lubrication system of the machine
379 Pressure Sensor automatic machine lubrication
380 contact pressure transducer modulation shift gearbox
381 Contact neutral position sensor lift lever (in the cockpit)
382 lever position sensor coupling
383 position sensor coupling
384 shifter
385 contact sensor neutral position tilt (in the cockpit)
386 solenoid lifting hitch
387 Solenoid lowering hitch
388 Contact line solenoid coupling
389 The probe neutral auxiliary lever
The solenoid 390 controlling the flow of hydraulic oil through the forward clutch
The solenoid 391 controlling the flow of hydraulic oil through the reversing
392 solenoid oil supply
The solenoid 393 to drive the front wheels
The solenoid 394 controlling the flow of oil through the drive motor
395 solenoid switch actuator pressure of the front wheel
396 Light on lamp-wheel drive (AWD)
397 contact pressure transducer feed pump
398 pressure sensor in the front wheel drive
399 sensor to the control lever-wheel drive (AWD)
400 The secondary windings of ignition coils
More Fault Codes HERE Caterpillar DTC
on Dec 20, 2016 • Cars & Trucks
tip
DELL A425 SUBWOFFER PINOUT
CABLE PIN OUT
PIN 1 SPEAKER 1 PIN 5 SPEAKER 2 PIN 3 INPUT 1
PIN 4 INPUT 2 PIN 8 EXTERNAL VOLUME CONTROL PIN 2-5-7-9 GRD
PIN 8 MUST TO GROUNDED FOR MAXIMUM VOLUME OUTPUT
The control for the Effects Loop Mix seems to function like a master volume control. I get no sound in ay channel if the Effects Loop Mix control is in the "EFF" position (right) and sound...
That is the way it is supposed to work... It is a level control to control the level sent to an EXTERNAL effects unit. What external effects unit are you using? Brand and model please. If you proportion more to the effects loop, you want to make sure the EXTERNAL effects unit is on and its gain controls are up. The foot switch input should control the EXTERNAL effects unit when you plug the footswitch into the EXTERNAL unit. The footswitch input on the amp itself has NOTHING to do with the external effect loop, it only affects the amp's own DFX unit.
My both A and B left speakers are noising (When something is playing, the're making some white noise) . What should I do ??
What source is selected when this happens? Badly-tuned FM radio or undecoded DTS from an external source could make loud white noise?
Just the left? Suspect the source if it's external. Swap left and right inputs to see if it follows.
Multiple sources? The amp is causing it.
There is the slighest chance that a common control may have developed a high-resistance or 'dead' spot and is causing your symptom. Turn the POWER OFF and operate every control throughout its range a number of times, especially rarely-used ones like Tape Monitors and the Mute control.
Maked sure your speaker wires are physically isolated or at right angles to power cords, devices with motors, TV
How to change the tv mode. Its on AV mode and i want to change it back to TV mode
Hello
You can set the Game mode and External input mode at the same time by pressing the GAME button on the remote control. "GAME" appears on the TV screen. To exit the the Game mode and the external input mode, press the GAME button on the remote control again. To cancel GAME mode only, adjust the PICTURE control. The game mode will be set ot 'OFF" automatically. In this case "VIDEO" instead of "GAME" appeares on the TV screen. When you press the GAME button if the TV is off, the TV turns ON and will be in the GAME mode and external input mode automatically.
How do I get the game mode back on?
[USING THE GAME BUTTON]
You may also set the Game mode and external
GAME button on the remote control. “GAME”
● To exit the Game mode and external input
control again.
● To cancel the Game mode only, adjust the
picture control. The Game mode will be set to
[OFF] automatically as explained in the previous
section. In this case, “VIDEO”(external
input mode) instead of “GAME” appears on
the TV screen.
● When you press the GAME button if the TV is
off, the TV turns on and will be in the Game
good luck
4helpful
Not able to enter phone number under new receipient dia
This usually occurs after an Internet Explorer upgrade. I spent days banging my head against the wall searching for solutions, when I stumbled across this. It fixes the problem every time.
WinFax PRO hangs or shuts down
- during installation
- when prompting for a phone number/CSID
- editing a phonebook entry
- adding/editing an IP address, or setting up Host Sharing
The problem started occuring after installing Internet Explorer 7/8.
SOLUTION:
1. In CONTROL PANEL, Click on REGIONAL AND LANGUAGE OPTIONS
2. Click on the LANGUAGES Tab.
3. Under "TEXT SERVICES AND INPUT LANGUAGES" Click on the DETAILS button.
4. Click the ADVANCED Tab.
5. Under System Configuration, enable the option "Turn off advanced text services" (Put the CHECK mark in this box.)
6. Click OK.
7. Restart the computer and then try WinFax PRO / TalkWorks PRO again. Number entry should now work in WinFax.
8. Now go back to the control panel following the steps above and undo step 5, un-check the option "Turn off advanced text services."
Note
• To open Regional and Language Options, click Start, click Control Panel, click Date, Time, Language, and Regional Options, and then click Regional and Language Options.
• Use this procedure to turn off handwriting recognition, speech recognition, and some accessibility features temporarily. These services can affect performance, and if you are not using them with your current program, you can turn them off temporarily.
• If you are not using a text service at all, you should remove it.
• Turning off text services does not affect multiple languages or keyboards that you have added under Installed services on the Text Services and Input Languages dialog box.
Parental Control Lock keeps blocking
I have the same tv and the only way to stop it going in to parent safe mode is to get a better signal or use a external source (Digital tuner, Cable box, etc.)
Accessing External Inputs Settings
you have to use the remote control for the tv not the dvr.
the dvr control likely cannot control the tv inputs programming unless you can program the correct code. and most new lcd panels don't have the correct codes for existing remotes
access using ext on the tv remote.
you may have to go into the menu and tell the tv what the ext is set to ie.. a channel or a input.
Top Motorola Mobility Cell Phones Experts
AFIFUL HAQUE MUFTI...
Level 1 Expert
vince
john h
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
