Question about Whirlpool GS475LEKS Gas Kitchen Range
My Whirpool Oven
Wish I could say this is the first time. I was cleaning my oven today and it suddenly turned off the front panel. Now the oven is locked, there is no electricity and I am not sure if the stove is fried or if the brain is gone again.
  • 869 Answers
Bad door latch
Posted on Jun 01, 2008
SOURCE:
I went to use the auto clean on my oven....turned the knob to "auto clean" then turned the oven door latch to the right to lock it. i found out the auto clean took 4 hours (don't have time to do it today)...
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Sep 08, 2010 | Hotpoint RB787 Electric Kitchen Range
I used the self cleaning for the top oven of my double whirpool Accubake ovens today. It worked fine during the process. But now, after it has cooled down. The panel is not lit up with the clock etc. and I...
There is a non-resettable fuse on the back of the oven that will have to be replaced. The oven will have to be removed from the wall and the back panel removed from the oven to access the fuse.
Nov 22, 2009 | Whirlpool RBD305PD Electric Double Oven
Whirpool Accubake Control Panel
try turning power off and wait 10mins and see if it resets.
Sep 14, 2009 | Whirlpool RBD305PD Electric Double Oven
Self cleaned oven for first time. when through
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
llhj
Jul 14, 2009 | DCS (WOTD-227) Double Oven
My KERS 807 SSS Stove works fine but not oven
sonds like a bad hightemo thermostat, loacted on the back wall behind the rear panel, common issie for ovens ,espessially after going through a self-cleaning,part number 9759242, part is about $50 turn off power before attempting to change, LIVE WIRES!!!!
Nov 30, 2008 | KitchenAid KERS807SSS Electric Kitchen...
Instructions required
I have a GE double oven. JKP44G with touch pad controls
Top oven door will not lock for cleaning cycle. I think I need a new motor for that.
Bottom oven will work sometimes and other times when I turn it on and select the temperature, thinking it is coming on - all of a sudden the temp light goes out like the oven is off and the oven does not heat. Sometimes I touch the clear button and then turn it on. Sometimes it works and other times not.
Could the connections in the control panel be dirty and not making connection at times?
Main question. How do I get to the control panel. How can I pull the oven out to clean the circuit or connectors and change the door motor. If I could just get into the panel I feel I could fix it.
Nov 14, 2008 | Ovens
Whirpool oven
HI the sensor can be replaced from the back and front. 1 screw holds it in the oven . remove back panel disconnect the sensor . thanks the appliance doc. please rate my answer. thanks
Oct 09, 2008 | Ovens
MGR5755QDS disable control panel lock
The clean cycle heats the oven to a very high temperature to burn off the dirt. The oven stays hot for a long time after cleaning. The stove will lock itself as a safety feature for several hours until it cools down. If this goes on for more than 4 hours after the clean cycle is over, call the Whirpool Customer Care number (in the US, I assume): 1-866-698-2538
Nov 08, 2007 | Whirlpool GR399LXHS Electric Kitchen Range
Whirlpool GS475LEKS Gas Kitchen Range Logo
63 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Ismael Rodriguez...
Archie Ferrarini
Archie Ferrarini
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
