Question about Waring PBB 201 / 204 / 209 / 212 Professional Work Top Blender
Waring blender bg5000 loud pitch noise not blending---burnt smell
I, i just received a new bg5000 said to be equivalent of 51BL25 model. problem is when i tried to make a smoothie it makes a really high pitch loud noise and i don't see the frozen bits and milk blending at all inside. i ran it without the jar and it runs find and there is no loud/high pitch noise. what is going on? it seemed that sometimes it would "engage" and most of the time it woudl not. ah, also when that is going on it would start to smell like something burning inside. i also tried lifting and put it back to see if itwas problem with the wheel not sitting properly, and it is not that. helped! i am sick of throwing out my waring blenders.
SOURCE: stopped blending
Exact same problem.  Turned out the threaded shaft that holds the blades was broken so tightening the nut on the top doesn't really help.  Just ordered a new blade assembly from www.smallappliance.com.  Mine was the Waring 007314W Blender Cutting Assembly but there is also an older one for earlier models.  Don't know if it will work yet (assume it will), but cheaper than buying a new blender.
Posted on Dec 16, 2007
  • 3 Answers
SOURCE: Waring blender BB180
try to soak hot water around the base unplug firts and pour hot water slowly at the base
Posted on Jan 01, 2008
SOURCE: waring pro wpb blender emit burning smoke and
Obviously the motor winding is burned out. it needs to be rewound. This is can be done only by repair men who regularly wind motors.
All blenders have one thing in common. They draw more than rated current when running slow. If u continued using it inspite of noticing low speed then the it results in burnt motor winding as is the case now.
Also the blenders should not be run on no load, which will cause meahanical damage to fan and bearings.
Posted on Oct 17, 2009
  • 394 Answers
SOURCE: i have a waring
Hi I am Steve, lets get you some help.
I assume this is the retaining collar on the blender that you twist to release the top assembly rather than anything else.
It could just be out of alignment and gently shaking the bowl whilst applying a pressure to the collar may clear whatever is causing the jam.
Posted on Feb 06, 2011
SOURCE: How do you get the blender coupling driver off the
how do you change the coupler on a waring extreme blender
Posted on Apr 08, 2011
After blending cake batter the blender became hot and it's not working what shall I do
You have burnt up the machine. It will no longer function and would be unsafe to try further. Replace it.
Jun 03, 2017 | Philips HR1350 SingleSpeed Handheld...
Waring blender shoots food out the top
Are you blending something hot? When you blend a hot item the steam that is released will increase the pressure in the headspace above the contents in the blender. The lid will eventually blow off to release the pressure.
To avoid this problem begin blending with no more that one cup of ingredients. Before turning the blender on, remove the center lid insert to allow venting of steam. Blend on low speed. As you blend you can add another 1 1/2 cups of additional liquid through the opening in the lid.
Trust this method will resolve your problem.
Oct 22, 2011 | Waring 6000CG 60th Anniversary Blender
Waring 34BL87 blender is loud and gives off a strong burning smell whenever used. Burning smell apparent since first day of use and getting worse with age. Is this odor normal or does it indicate the...
no, that is not normal. it could be from a loose or misallignment rotor or shafting. if its under warranty you should return it from the store...
Jun 17, 2011 | Waring TG15 Blender
Waring pro wpb blender emit burning smoke and smell when i was blending ...
Oct 16, 2009 | Waring WPB 01 / 04 / 05 / 09 Professional...
51BL25 (model number) It was getting really loud and then would not break ice or frozen fruit, and then it kinda "died". I could smell something hot from the motor
None of this is good news for your blender.
since new ones are less expensive than a repair it would be wise to go to walmart and get a new one.
May 23, 2009 | Blenders
Waring blender - model 51bl25
My Waring 51BL16 is having difficulty blending and some mechanism on the inside keeps spinning once the blender has been turned off...any ideas?
Mar 15, 2009 | Waring PBB 201 / 204 / 209 / 212...
Waring Pro Blender is leaking and blade assembly is loose
I know this is an old, old post, but I could not find a solution anywhere, so hopefully this will help someone. We have a model 51BL25, similar to scottman55's blender, and it had the same problem. There are two separate nuts in the blade assembly. One holds the blade on, and the other holds the seal tight. When the latter gets loose, the blender shakes and leaks.
To fix it, first you have to remove the top nut holding the blade on. I had to get in there with pliers, but a ratchet with an extension would be perfect. This nut is right-handed ("normal"). Once that nut is loose, you can remove the nut and the blade. You will also want to remove the washer immediately under the blade (take note of which side goes up).
Now, you can pull the whole axle out by the wheel on bottom of the blender. This exposes a really thin, flat nut. In my case, this nut had come completely off, so nothing was really holding the seal together at all. Again, make sure you remember which direction the nut goes -- it is not quite symmetrical. That nut is what comes loose when the blender starts leaking. By the way, it is a left-handed nut, so it screws on counter-clockwise ("backwards"). Screw it in tight, then put the rest of the blade assembly back together, and your done. If you have the right tools, it should take only maybe 5 minutes.
Depending on your problem/model, this may or may not solve your problem. Hope it helps!
Jan 28, 2009 | Blenders
Stopped blending
May 17, 2007 | Waring PBB 25 Professional Work Top...
Waring PBB 201 / 204 / 209 / 212 Professional Work Top Blender Logo
141 people viewed this question
Top Waring Blenders Experts
AZBen
AZBen
eyecam
Are you a Waring Blender Expert? Answer questions, earn points and help others
