LG WM-3677HW Front Load All-in-One Washer / Dryer GENERATES "CD" ERROR DURING DRYING CYCLE.
CD means cool down, press the pause start button, the door lock will open. It is an anti crease cycle. It mentions it in the owners manual, but it is hidden deep in the drying section.
Sgt 48
LG/combo 1481rd clothes coming out wet after drying on very heat. I have cleaned out the condensing duct, replaced both drain and circ pumps and the two sensors going too heater, condensor tube. No error codes, but lots of wet washing . I remove all the washing but for one towel and tried again twice because the machine went out on UE the fist time. checked water value OK with 65 openings on dryer cycle. can you re-program this funtion or is it controled by the sensors which I have replaced.
Have you checked to make sure the cold/hot water are properly connected? Another part that causes this failure is the 4-way valve.
I have the same exact problem. At the end of the washing and drying cycle, the screen shows "End" but the doors remain locked. After about 3 minutes, the "Door Locked Light" turns off and the screen shows "Cd". However the doors are still locked and the clothes start to spin again.
I have exactly the same problem but my LG washing machine model is WD-14336ADK
I have the same problem but when I press the pause/start button the "cd" goes off but the door remains locked for several hours.
how to install a siphon break kit onto a LG front loading washer
Problem with LG WM2277H front load washer
Always moving excessively during operation
smoke coming out of drum
how to change pump
