FixYa.com
Tags:
Toshiba PA2502U - Libretto 100, 110, 100CT, 110CT Series Laptop Battery Power Supply
Mx35 no power
posted by emojmo on Sep 01, 2007
My Toshiba laptop will not charge. Not sure if the problem is the battery or the cord not working properly.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Feb 12, 2008
Not Rated (0)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
i had the exact same problem and my toshiba laptop NEVER left my desk and i NEVER wrapped my cord around and around...eventually it would just shut off more and more and then one day i was never able to get it to turn back on. my power cord was okay and my battery was just fine. it had something to do with my motherboard and it was cheaper for me to just buy a new laptop then it was to fix it.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Sep 04, 2007
Not Rated (0)
dodgecharger
Rank:Wiz Wiz
Rating: 82%, 246 votes
If you have said multimeter, you could check the power cord (cord which plugs into the AC 110volt house current) for continuity, assuming this cord unplugs from the power supply. Use the ohm meter function to do this, and cord must be unplugged to do this.
One problem which happens with laptop power supplies is the user (you) often wrap the cords around the box over and over again, and the wiring eventually fatigues and breaks, resulting in no power output or perhaps intermittent power if the cord is positioned just right. (especially referring here to the cord from the box to the laptop) A break like this can be repaired- a tech savvy person could disassemble the box part, unsolder the card, cut the bad part out, and resolder/redress it. I've done this on a couple units here at the college where I work, both having the exact problem described here.
Solution #3
posted on Sep 02, 2007
Not Rated (0)
mistyman
Rank:Wiz Wiz
Rating: 81%, 272 votes
Hi, can you use a multimeter?
If so then check on the power suply what the voltage output should be for that unit.
Then with the power turned on GREAT CAUTION MUST BE TAKEN AT THIS STAGE AS TESTING THE WRONG END COULD CAUSE ELECTROCUTION use the meter to test the laptop end plug only and see what power output you have.
If you can not do this then take the power supply to a technician and have it tested. If ok = dead battery, if not replace power unit.
Regards mistyman
Can you Help with these System Power Supplies problems?
electronics design
how to design unregulated power... Answer This...
Power Adaptor for 500GB LaCie...
Hi, My LaCie 500GB Porsche USB... Answer This...
Lanier VoiceWrite EX won't come...
The on/off button will not work... Answer This...
paper presentation
sir i am bala doing MCA ple... Answer This...
Battery charger
Dear Sir/Madam, I want to know... Answer This...
Repair Service
Find System Power Sup. Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
