Question about Zanussi FLA1001W Front Load Washer
Washer won't spin correctly after fitting new bearings
On any program the washer will not spin correctly. For example On the fast spin program the washer will start to drain water (water pump activates). The drum starts to spin for about 5 to 10 seconds then stops. The pump continues and the program doesn't move on. This happens on all other programs. The washer seems to be able to control the water correctly but only spins the drum once for about 5 to 10 second period then stops. If I turn the washer off then on again(in mid program). The drum again spins for that short period but no more. Here's what I did when fitting the bearings. Fitted new drum bearings this involved removing the drum unit with motor. Splitting drum unit and removing the stainless steel drum, removing and replacing bearings and building it all back together. I had no problems other than getting the removing the old bearing off the shaft. I've check all the wiring loom connections. I'm just really disappointed that the drum runs really smooth but I've managed to break something else in the process. I've read about an off balance switch shutting the machine down. I'm thinking if this sensor is in the drum I may have up set it. I can only see two electrical devices in the drum unit one being the heater element and I'm guessing the other is water temp sensor. Any help would be useful.
  • mnc_co_uk Sep 02, 2007
    The motor and drum spin at the start of the cycle for about 5 to 10 seconds. After that the motor or drum does not spin at all during the cycle.
    Based on your advise I went over all the connections, again, to the module and all other connections I could find making sure they were all in good contact.
    Fired the machine up and it now seems to be working fine.
    So problem solved!!
    Thanks
Sorry this has not helped, as an engineer of 20 years some problems can be easily sorted, some take longer and can only be found with test equipment or hands on approach, if you have access to ready spares, start by replacing the module, although i do suspect its something thats been disturbed (wire on the timer), even we get it wrong sometimes?
Posted on Sep 02, 2007
  • 209 Answers
There are no others sensors in the drum, the module (a circuit board) controls the actions of the timer, it may be one or so wires were disturbed at the time of repair, check all connections, any out of balance sensors would only work with a heavy loaded drum? You did not comment as to the motor / drum action when washing from the start of the cycle?
2005 rodeo diesel 3lt turbo 2wd. No abs . New frount bearing kit can not fit dust seal on inner bearing if you do have to tighten nut to tight wheel doesnt spin?
if they are tapered roller bearings they should never be tightened too tight. they will war out and fail real fast. maybe one your races isnt seated correctly?? are they tapered bearings you replaced. did you remove the old races??
Nov 10, 2018 | Cars & Trucks
Samsung washer wf218anw
Possible that the washer is not stable due to level adjustment. Use a spirit level to set the washer so that it will be stable. Check the drum movement and the motor /drum mountings.If you find there is PLAY on the fittings then it must be reset.
Check this link: Drum Bearings.
Jan 19, 2013 | Samsung WF203ANW Front Load Washer
The machine doesn't spin properly and doesn't drain the water
see this causes and fix it. God bless you
Lid Switch Assembly If the washer won't spin the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Motor Coupling If the washer won't spin the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission. Another common problem is the lid switch.
Drive Belt If the washer won't spin, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin properly.
Door Lock Motor and Switch Assembly If the washer spin the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Drive Block If the washer won't spin the drive block might be worn out or may have come loose. Underneath the agitator the drive block connects the inner tub (the one that spins around) to the transmission. If the drive block wears out the transmission shaft will still spin but the tub may not - or it may spin slowly. This also usually causes a lot of noise. The drive block is relatively easy to replace.
Clutch Assembly If the washer won't spin, the clutch assembly might be worn out. The clutch assembly makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may prevent the tub from spinning. The clutch is not repairable, if it is loud or not working properly it will need to be replaced.
Clutch Band kit If the washer won't spin, the clutch band kit might be worn out. The clutch makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may prevent the tub from spinning. If the washer won't spin, this clutch band kit may need to be replaced.
Drive Motor If the washer won't spin the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged It will have to be replaced.
Tub Bearing If the washer won't spin the tub bearing might have seized. This is a common problem and relatively easy to replace.
Tub Seal and Bearing Kit If the washer won't spin the tub seal and bearing might have seized. This is a common problem and relatively easy to replace.
Bearing If the washer won't spin the bearing might have seized. This is not common. The bearing doesn't require any normal maintenance. They generally go bad when the tub seal fails and allows water to leak past into the bearing.
Basket Drive If the washer won't spin the basket drive clutch might be worn out. The basket drive sits on top of the transmission and engages with the inner tub. If the basket drive wears out the tub won't spin.
Basket Drive Hub Kit If the washer won't spin the basket drive hub might be worn out. The hub is a set of plastic gears underneath the agitator. The basket drive hub kit is easy to replace with standard hand tools.
Transmission If the washer won't spin the transmission might be worn out or defective. There are numerous more likely causes when a washer won't spin, which should be checked first.
Sep 28, 2012 | Hotpoint Washing Machines
When in spin cycle sounds like a large bolt is spinning around washer shakes spin cycle really fast scrapeing noise
The scraping noise is the grinding noise from the worn out ball bearings. Replace them. You can open the back cover by removing the screws. To fix new bearings remove the drum wheel & then the bearings. It is purely a mechanical job.
- sonsunny
Jul 09, 2011 | Washing Machines
Excessive noise - possibly dry bearing - particularly when on 'fast spin'.
Sound like your bearings ok, this machine does have a bearing kit available but you will need a professional to fit as it is not a simple fix and will take about 2 hours. Hope this helps.
Feb 28, 2011 | Hotpoint WMA54 Front Load Washer
I have a Hotpoint WF540 washing machine. When it goes into fast spin, the spin cycle is quite noisy....on slow spin it is fine......could this be a bearing problem? If so how easy are they to replace?
Sounds like drum bearings most cases you need to buy half drum with bearings fitted if your very good at diy no problem if not call engineer.1st check concrete weights are not loose top and bottom.............you can buy parts @ espares.co.uk this will give you idea of cost which maybe quite high.
Apr 21, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Drive belt on hotpoint wm56 keeps coming off when machine goes on fast spin. I have fitted a new belt but it still keeps happening.
Make sure belt is reasonably tight, and it is in the center of the drum pulley, if it still comes off, then I would suspect that the drum bearings are worn, or the drum is running out of alighnment, or the motor bearings are worn, if it is noisy when you spin the drum by hand, then the bearings have definately failed.
Please rate my solution.
Thanks.
Sep 22, 2009 | Hotpoint WM56 Front Load Washer
My washer turn on but won,t spin
tub bearings may be frozen up. Can you move tub by hand?
Jul 20, 2009 | GE WPGT9360EPL Top Load Washer
Frigidare front loader washer GLTF1040ASO
your bearings are shot your washer needs to be rebuilt but it is cheaper to buy a new washer
Dec 26, 2008 | Washing Machines
Bearing replacement on Creda IWD 12drum DIY or not?
no im afraid thisis not a DIY job and i charge £120 pounds to supply and fit new bearings and spider  and you should also get @ least 6mths g/tee on parts fitted         good luck
Mar 03, 2008 | Creda W100FW Front Load Washer
Zanussi FLA1001W Front Load Washer Logo
125 people viewed this question
Top Zanussi Washing Machines Experts
shaun taylor
Marvin
Marvin
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
