Question about Kenmore 15129 Built-in Dishwasher
Kenmore Elite My top rack is not cleaning, but the bottom rack seems to be working fine. Has anyone else had this problem with a Kenmore elite?
  • 1 more comment
  • chris kelley Nov 05, 2007
    im haveing the same problem. it seems that it not pumping the water hard enough. bottom does great.
  • Anonymous Nov 18, 2007
    I also have the same issue. If anyone finds out the issue, please let us know.
  • Anonymous Feb 28, 2009
    I have the same problem. top rack dirty- bottom rack clean.
    Nothing clogging the drain area to restrict water flow - suggestion to check the "solenoid", so what does a solenoid look like, so I can checki t?
I also have this problem, and my unit is only about 1 year old. The bottom gets clean but the top does not. I cannot see anything clogged or stuck open.
I'd appreciate more possible answers.
Thanks
Posted on Jan 24, 2008
  • 833 Answers
This is a guess but worth trying:
First, check to see if there is any food material in the drain area. There is a screen which may be restricted. This will restrict water flow. Second, if that doesn't work, there is a solenoid which directs water from the pump to either the drain or to the wash nozzles. It is probably stuck part way. It may be cleaned. I once found a toothpick in one!
Posted on Dec 26, 2007
Kenmore elite refrigerator is not cooling, but the freezer seems to be working fine.
Kenmore Elite refrigerators come in several styles, including units with a freezer at the top and units with freezers at the bottom. The top and bottom of the fridge work on different systems. Sometimes the freezer may function perfectly, while the fridge performs poorly. Most issues with the fridge cooling are due to incorrect settings or poor cleaning practices. Checking common problems with the refrigerator will help you diagnose the situation and keep expensive repairs to a minimum
1. Check that the Kenmore Elite refrigerator is plugged in. Inspect the circuit breaker of the home if the refrigerator is plugged in but not running.
2. Pull the unit out from the wall and vacuum the condenser coils at the back of the unit.
3. Turn the temperature control in the Kenmore Elite refrigerator to the "On" position.
4. Turn up the temperature on the temperature control, located inside the unit on the wall.
5. Check the seal along the door for signs of cracks or dryness. If it is damaged, lift up on the seal to expose the screws that hold it in place. Loosen the screws and pull the seal off. Place a new seal on the unit, starting in the corners and working your way around to insert the tabs into the Kenmore Elite fridge door.
6. Check the seal along the door for signs of cracks or dryness. If it is damaged, lift up on the seal to expose the screws that hold it in place. Loosen the screws and pull the seal off. Place a new seal on the unit, starting in the corners and working your way around to insert the tabs into the fridge door.
7. Move food away from the vents inside the Kenmore Elite refrigerator.
I hope i solve you problem.
Have a nice day : )
Sep 04, 2011 | Refrigerators
Kenmore elite model 665 17263402 The top rack is not cleaning the dishes. The bottom rack is cleaning fine. What is causing this and how can I fix it? Please help.
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Jan 16, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
No air coming into refrig to cool
We pulled the back panel in the freezer and found the coils frozen. We defrosted the coils and the fridge started working. We will be getting a new timer. Thanks
May 29, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Range/oven Burners won't lite
Ours did the same, I unplugged the stove for 1 minute and afterwards the burners worked fine.
May 19, 2009 | Kenmore 75844 / 75849 Gas Kitchen Range
The top rack on my kenmore dishwasher is not cleaning the dishes!
check the inlet strainer at the bottom of the unit - and also the nozzles on the top are for clogs/sediment.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 16, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Bottom Freezer - only top does not work
i would check to see if you hear a an blowing in the freezer sect when the door is opened, if you cant hear the fan blowing then there is yout issue, not circulating air up to refrig compartment
Nov 11, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite Mod #76523
The problem is the fan unit that pushes cold air up to the fridg, usually located nere the back of the freezer.
Aug 19, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore 15129 Built-in Dishwasher Logo
188 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
