Question about Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer
Burnt smell in dryer
Duet electric dryer has a burnt smell when using the heat setting.
Eliminate the dryer sheets and use liquid fabric softener. The burnt smell is GONE!!
Posted on Nov 27, 2007
  • 641 Answers
Open the service panel and check that the heating element is clear from any lint on it. Be awre you should unplug the power cable before touching the heating element. Good luck!
Posted on Sep 02, 2007
SOURCE:
Burning smell in dryer
Have you checked the motor? Plenty of lint and dust gets indie it. If you can remove if and use compressed air to blow it out. Also don't overlook the fact all the spade connectors will also collect lots of lint and dust which is quite flammable. Also check the tensioner and guide wheel they get pretty dirty and when they heat up the lint can start buring.
Aug 11, 2014 | Kenmore Elite Oasis 6808 Electric Dryer
Neptune dryer turns on and works for about 10 minutes, then shuts off. When the door is opened it is very hot and has a burnt smell. The only setting that does not have a burnt smell is air fluff. All...
remove the front cover and drum and clean out all lint including lint filter blower wheel housing and all exhaust vent piping from inside dryer to outside discharge,if this is done and it persists,replace the cycling switch and high-limit thermostat as these may have welded themselves and can no longer control heat
Aug 23, 2011 | Maytag Neptune MDE5500AY Electric Dryer
My Whirlpool Duet dryer has a strong. "Burnt"
Hi
The burnt smell usually comes when the motor is going bad, as the unit works I won't recommend you to use it for a long time and get the motor checked-replaced. Hope this helps...please post back for further assistance.
Daniel
Jan 21, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Smell gas coming from whirlpool duet gas dryer. Its not the gas line.
Hi, Often times that is because it is not lighting right...
If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Nov 04, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Kenmore 70 dryer smells burnt
There could be dust settled on the motor inside from the few years in storage. Unplug and remove back, with a hoover brush **** off all dust but do this lightly as to not disturb any connections.
Jan 04, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Heard a loud pop...saw a bright flash...burnt smelled and dryer stopped working. Circuit breaker will not re-set.
You may have a wire that has come loose of it's restraints and is rubbing on the drum as it turns. This would cause the wire's insulation to wear off, and if it's an electric dryer, you're dealing with 220volt wiring. The spark and burning smell is similar to arc welding.
You'll need to open the dryer up and find the damaged wire and reinsulate it with electrical tape or heat-shrink wrap.
It should be easily visible ...look for the burnt,blackened marks..
Nov 01, 2009 | Frigidaire Dryers
Clothes smell burnt
THERE SHOULD BE TWO SCREWS ON TOP OF THE PANEL UNDER THE DOOR ONCE YOU REMOVE THESE THE PANEL SOULD COME OFF
Sep 21, 2009 | Whirlpool GEW9200L Electric Dryer
My Whirlpool duet dryer is getting too hot
YOU NEED A NEW THRMO KIT
STEVE'S APPLIANCE
516-300-3249
Mar 15, 2009 | Whirlpool LER5636P Electric Dryer
Back heating grate inside dryer has become dark like it's burnt
I used Bartender's Friend. You can find it at Home Depot. Its best to put it on a sponge, rub it on and let it set for about 5. Then scrub with a steel pot cleaner or copper one. It hard to do since the grid is in the back of the dryer but it came off!! Basically, clean it like you would a burnt pot or pan with the Bartender's Friend.
Sep 24, 2008 | KitchenAid KEYS850LQ Electric Dryer
Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer Logo
425 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
