Question about Kenwood KSC-WA100 Car Subwoofer
Ksc-wa100 i need to know the wireing diagram for the power/ wire harness
  • 3 more comments
  • Anonymous Mar 01, 2008
    need to know the wireing diagram to install a ksc-wa100 in a 1998 ford f150 regular cab truck.
  • alx850 Mar 22, 2008
    no wireing harness available, so i need the pin order
  • jankin990 May 28, 2008
    i need to know a wiring diagram, because i cannot buy the actual wiring harnest anymore. i need to know what wire, in what box, does what.
  • gr8tdane Jul 05, 2008
    I have the amp with the wiring code with pictures!! Email me at for the wiring diagram
  • youngboyfres May 10, 2009
    where did u find the piece to plug in all the wires because i need one
Posted on Jul 06, 2008
    An expert who has written 3 tips or uploaded 2 video tips.
  • 199 Answers
This is a step by step guide to wires and install for you
Posted on Feb 21, 2008
I need a diagram for the lighting harness and list of what each wires controls. i also need a list of the colored wires to determine what wiring effects. my dashlights are out.
It may be helpful to know the make of the vehicle, year, model, engine????
Free Automotive Wiring Diagram for ALL Make & Model ...
Free Automotive Wiring Diagram in Full Color for ALL Cars, Trucks, Vans and ... who just need to trace down one circuit (i.e. radio wiring diagram, a/c circuit, ...
How To Wire Fog And Driving Lights Harness Wiring Diagram
Position the lamps at an equal distance from the center of the vehicle and as far apart as ... Note: This is a general wiring diagram for automotive applications.
Automotive Wiring 101 - OnAllCylinders
Dec 5, 2013 - Automotive Wiring 101: Basic Tips, Tricks & Tools for Wiring YourVehicle ... This chart can be used to determine proper wire gauge. First .... A factorywiring harness includes the necessary wiring for standard electrical ... The gauge youneed depends on the current draw of the accessory and the wire length ...
Jan 23, 2016 | Cars & Trucks
Wire diagram for the a/c cooling fan.. 1991 Jeep Commache
I am sorry but fixya doesn't have any wiring diagrams. They are copyrighted and not free to share.
Jul 22, 2012 | Jeep Comanche Cars & Trucks
I have a kenwood krc-12 cassette receiver to hook up in my cherokee but no wiring diagram,i want to hook it up rightneed a wiring diagram.
it costs 12 bucks for the plug and wiring harness at wall mart for chryler/ jeep.with the wiring harness instructions are on or in the package.u will need the plug if you are useing the factory speakers and factory wiring in jeep for power.if not just copy the instructions off the will give you all you need to know,just match them up.and you should be all set/MAKE SURE YOU RECHECK ALL WIRING 2 OR 3 TIMES BEFORE PLUGING IN.
Dec 22, 2010 | Kenwood Car Audio & Video
Battery Constant 12v+ Positive Wire (+): Black/Orange And Red/White
Battery Constant 12v+ Positive Wire Location: Ignition Switch Harness
Starter Positive Wire (+): Yellow
Starter Positive Wire Location: Ignition Switch Harness
Ignition Positive Wire (+): Blue (16 Gauge)
Ignition Positive Wire Location: Ignition Switch Harness
Second Ignition Positive Wire (+): Yellow/Red
Second Ignition Positive Wire Location: Ignition Switch Harness
Accessory Positive Wire (+): Blue (10 Gauge)
Accessory Positive Wire Location: Ignition Switch Harness
Second Accessory Positive Wire (+): Orange
Second Accessory Positive Wire Location: Ignition Switch Harness
Parking Light Positive Wire (+): Black/Yellow
Parking Light Positive Wire Location: At Headlight Switch
Power Door Lock Positive Wire (+): Orange/Violet
Power Door Lock Positive Wire Location: In Drivers Kick Panel, White 6-Pin
Power Door Unlock Positive Wire (+): Pink/Violet
Power Door Unlock Positive Wire Location: In Drivers Kick Panel, White 12-Pin
Door Trigger Negative Wire (-): Yellow
Door Trigger Negative Wire Location: At Headlight Switch
Domelight Supervision Wire: Use Door Trigger (Requires Relay)
Domelight Supervision Wire Location: N/A
Horn Negative Wire (-): Black/Red
Horn Negative Wire Location: At Steering Column Harness
Tachometer Wire Negative Wire (-): Gray
Tachometer Wire Negative Wire Location: At PCM, Connector 1, Pin A7. The PCM (powertrain control module) is located on the firewall next to the wiper motor.
Brake Light Positive Wire (+): White/Tan
Brake Light Positive Wire Location: At Switch Above Brake Pedal
Factory Alarm Disarm Wire (-): Black/Orange (To disarm requires a (-) negative through a 1565 ohm resistor and an extra relay to connect.)
Factory Alarm Disarm Wire Location: In Drivers Kick Panel, White 12 Pin Plug
Factory Anti-Theft System: N/A
Factory Anti-Theft System Location: N/A
Aug 22, 2009 | 1998 Dodge Ram 3500 2WD
I need a wiring diagram for the stereo on a 2002 oldsmobile bravada. i am installing an aftermarket stereo with an open ended harness because the quick harness is like $100! every diagram i have so far is...
most car comapnies use the same colo coordination, red, power, black ground, blue power ant, you could always contact Oldsmobile and acquire at least the pages which give the information you need
Aug 13, 2009 | 2002 Oldsmobile Bravada
Suzuki 1999 Quadrunner LTF250F wiring harness issue
no power to my magneto on my 99 suzuki LT-F250F dont know what one of the four other wires should be power i found the ground please help
Apr 19, 2009 | Suzuki RGV 250 L Motorcycles
Need wiring diagram for Gmc envoy stereo
I dont believe its used in your situation .
here is a rundown
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox or ignition switch harness for switched power.
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: Brown
Car Stereo Dimmer Wire: Gray
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Mar 27, 2009 | 2006 GMC Envoy
Mazda B4000 2002 wiring in turn signal harnesses came out of plastic clip
i have a sujestion if you promise not to mark it as inapropiate i will give it to you , i'm sorry but some people don't relize than i'm here taking my time for free just to get some good feed back and after that they just mark the answer as inapropiate now i'm getting afraid or very specific when try to answer something
i hope and you understand but if interest with my sujestion just let me know and i will give it to you off course is not a diagram but will help a lot
Jun 03, 2008 | 2002 Mazda B-Series
Kenwood KSC-WA100 Car Subwoofer Logo
2,419 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
