Question about Sony Ericsson K550i Cellular Phone
My cell phone screen dont work ...help
My phone works just the screen dont work it gose on but its a blank screen..i get calls i can make calls. i just dont know what number iam putting in..i have a razor v3 and on the back i know i have alittle water damage but it works just not the screen..help me I have a sonny ericesson and the screen is like kinda black and all differnt colors. The phone still call and recieves call. What can I do to repair it?
    Problem Solver:
  • 13 Answers
Call a mobile shop
Posted on Apr 12, 2009
SOURCE:
My 64 is not working on tv
The game cartridge contacts are probably just dirty and/or corroded. Clean em with rubbing alcohol and a q-tip. The games should work fine. Mine is the same way cause its so old. Even my Super Nintendo does it. Unfortunately, you may have to do this every time before playing, but only if they don't work the first time.
Sep 16, 2012 | Nintendo 64 Console
My nokia 5530 switch off when i make or receive call
hi dude.. i'm usng 5530 having same switch off when making call problem. i fond out where the problem is.. the problem is with the sensor of the mobile which is located on top of mobile.. just above the Xpressmusic sticker. (At the top of the Screen is a very well hidden Light Sensor)
http://www.flickr.com/photos/26382688@N03/4461077070/
IF YOU COVER THIS AREA PHONE WILL TURN BLACK and BLANK..
I know that you can make call in 2 ways. 1). While calling immediately put Loudspeaker , it will work ine till call ends in loud speaker. 2). using blue tooth headphone or normal headphone. (but you dont disconnect the call in headset. you can disconnect the call by pressing RED button in mobile). but still i'm unable to change the sensor of the 5530, so you try that first.. Changing the Sensor will be the best way. if i'm right , plz contact me ...
Feb 08, 2010 | Nokia 5530 XpressMusic Smartphone
After dialing via Contact, screen will go blank
try taking the battery out wait a couple minutes then put it back in. after this process it should work normaly
Jun 15, 2009 | LG Dare VX9700 Cell Phone
You most likely need a new ribbon cable, which is the cable that connects the two halves of the phone. They are not expensive and can be ordered on eBay, and they come with the tools required to disassemble the phone and replace the cable.
Jan 15, 2009 | Nokia 6085 Cellular Phone
My screen goes blank all the time...i would take the battery out put it back in and it works for a bit then agagin it would go blank...the phone otherwise accepts calls and makes calls.....please help
the problem is with the phone's display, or with the connector...but it also may be with the phone's software...so I guess you should give it a master reset...but I don't guarantee that it will work
Jul 23, 2008 | LG Shine KE970 Cellular Phone
Blank screen on kyocera cell phone
mymomcallsme solution works, I had the problem, removed battery fer a while, viola! Screen is back. Thanks mymomcallsme
May 01, 2008 | Kyocera Oystr KX9 Cellular Phone
Blank screen
well the inside screen is blank but the outside screen isn't icant text or see menus i can stilll dial the numbers just cant see them on the screen
Apr 17, 2008 | Cell Phones
This is a common problem, it has to do with the keypad flex. either the connector on the top part of your phone is unpluged or your flex is damaged. Open the top of the phone where the screen is at (4 torx screws) genlty remove the cover. you will see two connectors, one that goes to the camera, the other is the one you want. genlty pry it off upwards, I would also clean it with some IPA (rubbing alcohol) and a brush, re-connect it pushing down firmly, you will fill it when it connects. if it doesnt work, you can purchase a new flex, if you need repair help, let me know I can try to repair
Nov 12, 2007 | Motorola Mobility RAZR V3
Sony Ericsson K550i Cellular Phone Logo
107 people viewed this question
Top Sony Ericsson Cell Phones Experts
Damen Wong
Damen Wong
Marvin
Marvin
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
