Installed brand new dishwasher, won't start. Checked power, water intake, but nothing happens. Reset breaker, still nothing.
Comments:
Apr 03, 2009
- yes, it is brand new, never been used. Has water, has power, it just will do nothing, no flashing lights, zippo nothing. Have installed 4 other dishwashers in the past and never seen a problem like this one.
Apr 04, 2009
- Service technician found the problem. Control panel is defective. Is dishwasher was never used, Sears is replacing the dishwasher at no cost.
May be a wire off motor compacitor. You can't see it from the front. The compacitor is facing the back of the dishwasher. You may have to un-install it to check or use a mirror and flashlight. It's located behind the motor on the left side looking from the front of the machine.
unit appears to go through all the cycles, including pumping water into the unit and back out again....
(More)
unit appears to go through all the cycles, including pumping water into the unit and back out again. But there is no 'water pressure' during the wash cycle. Can you direct me to where I should start checking?
water leaks from the bottom right corner of door of countertop model on the rinse cycle how can I...
(More)
water leaks from the bottom right corner of door of countertop model on the rinse cycle how can I fix it
