My I-pod was low on battery and then it just turned off. When i try to charge it on the computer it wont charge and when i try to reset it, it wont turn on.the apple doesnt appear. What should i do?
battery ran out and wen i plugged it in it says please wait very low battery. it wont reset or turn on or off wat the hell do i do?? battery ran out and wen i plugged it in it says please wait very low battery. it wont reset or turn on or off wat the hell do i do??
AnonymousApr 18, 2009
my ipod won't charge no matter what power source i trymy ipod won't charge no matter what power source i try
You can't post conmments that contain an email address.
How old is the battery ipod batteries can only be recharged a certain ammount of times before they need replacing
If an iPod appears not to turn on, check the hold switch on the device. If this switch is activated while the device is off, it will not power on again until the hold switch is turned off.
If that is determined not to be the problem, the battery's charge should be checked. When the battery is no longer holding a charge, the device will not power on, but will show a battery icon on the screen for a few seconds. If you see this icon while trying to boot up the iPod, just connect it to the USB cable and allow the battery to charge, which can sometimes take up to 30 minutes before the iPod becomes operable again.
If no battery icon appears when trying to turn on the device, try resetting the iPod. Once reset, the device should turn on, but if it does not, the battery may need to be drained first (by leaving the iPod disconnected from power for up to 24 hours), and the reset procedure tried again. hope this helps
1.Check the device's battery level for at least two bars of strength. 2.If the battery level is low, charge the battery. 3.If the issue is not resolved, remove the back cover. 4.Remove the battery. 5.Wait 10 seconds. 6.Press and hold the W key. 7.While pressing down the W key, re-insert the battery. •The device restarts and after approximately 15 seconds, the 'Recovery' screen appears •Release the power button but *continue holding the home button*, for another 30 seconds. Step Thanks
This may not be the answer you are looking for but your I pod might not be fully charged, meaning that you are not plugging it in the computer/docking system long enough.( it takes much longer than 15 minutes to charge the battery. So you might want to plug it in/dock it over night) Or you may be playing a game that uses a lot of MB/GB so it kills the battery. And make sure that you press the play/pause button down for at least five seconds before switching the little switch at the top of your I pod. If you don't press the play/pause button for five seconds and just switch the switch at the top a little lock will appear on the left corner meaning you need to hold the play/pause button down for five seconds then the i pod screen goes black at that time flick the switch at the top off.
-hope it helps
owner of i pod nano and I pod touch.
Apple does this so that only Certified accessories have to software to make the hardware circuits charge an i pod, thats especially a problem with some sound docks, my i pod 2 gen works with only 1 of the 3 sound docks that i have tried, but i have a bluetooth i home so i play my music wirelessly
try reseting it with holding down the menu and center button. Your warrenty will have been voided due to the liquid damage though so if you cant get it working with the reset your gunna need a new one.
Hi I think your battery may be going bad or you need to purchase a wall charger to fully charge your battery. Charging your iPod on your computer works fine for a while, but as the battery gets older, it needs more charging and often it doesn't get enough from the computer. Try a wall charger first. Charge it all the way up until it stops charging. If it still shows a low battery you need to have a new battery. There are a lot of places that can do it. Hope that helps.
