Question about Canon PowerShot SD600 Digital Camera
Lens error I keep this Elph in a tiny, padded Halliburton case because the last TWO I bought ended up with broken screens. I never had a problem, though lightly used. Last night I recharged the battery and inserted it. Immediately upon power-up, the lens went out and I got a "Lens error, restart camera" error. I turned it on and off about twenty times, left the battery out overnight: same thing. I jiggled the lens with the same result. Canon tech support told me to take the battery out and toggle the power switch seven times. Same deal. So they said to send it in. But I have no idea where my POP is and it may be over a year old. Any ideas? Thanks, Rick
  • 3 more comments
  • rmccabe Sep 01, 2007
    Canon PowerShot SD 600, lens stuck out.
  • gotjtt Nov 03, 2007
    my camera fell out of my bag, [ but it was off] then i turned it on, it still worsk for about 10 minutes, then the screen start turning black. on it said " lens error, restart camera" what do i do? the lens wont close.
  • Kelkenko Nov 16, 2007
    I have the same problem with my SD 600. The lens will not open and the
    message reads lens error restart camera. Any suggestions short of trying to send it in for repair. Unit was not dropped or abbused.
  • juan alvarado May 14, 2008
    my case is diffrent ,i accidently droped my camera and the lens is stuck and i got an error mesage on my screen
  • George_C May 26, 2008
    When camera is turned on lens is stuck and I get the message "Lens error. Restart camera." Have tried removing the battery and toggle the on/off switch 7 tmes but no luck. May have to send it in for repair.
    GC
    Genius:
  • 2,985 Answers
Lens mechanism has failed and a repair/replacement is the only solution-
Posted on Sep 22, 2007
Question about Canon PowerShot SD1300 IS Digital ELPH Camera
common problem ask the photo shop.
1- the powershot is set on when the battery is to low
then the lens will be blocked due to less current.
2-the lens is blocked bij a little tiny sandpiece.
Jan 24, 2018 | Canon Cameras
Everytime you turn it on it loads then turns itself off without retracting the lens and does it everytime you try to use it
I dropped my CANON IXUS 65 on tarmac, while lens was extended. Thereafter would not retract and lens error. The IXUS 65 is european version of USA SD60 or SD630 Digital ELPH.
Tried pushing the lens back as explained below, clicked , but still would not work. I disassembeled the camera and removed the lens/motor assy. Then disassembeled the lens assy. 1 tiny pin had become dislodged causing the problem. 2 more of same tiny pins fell out. Now im not yet sure how/where they go back into place. If I cannot figure it out I see one can buy a new lens assy for circa $30 and just install it. I used my mobile phone camera to take video and shots of the disassembly steps. This to help re-assemble. I also disassembeled/ reassembeled several times as its trick and lots of tiny screws. To remove the pcb cables one gently pulls them using a small plyers or plastic gripper. Gerrykenny@yahoo.ie
Apr 20, 2011 | Cameras
Hi! Im Michelle from Dubai UAE, i bought my canon elph series camera last july 09 only and just yesterday after turning on the device the lens was stock up and not turning to its place anymore,.i tried to...
hello.....
sir it might be a lense problem i guess............the spring with which lense moves may be not proper............. slidin of lense is not aceessble by ur cam...........so better if show it to ur provider.......they replace it to u .......if u have warranty card then it is well and good........
Oct 14, 2009 | Canon Elph Jr. APS Point and Shoot Camera
Dropped camera- lens will not go back in-
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Feb 20, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
In the screen says lens error
Hi I had the same problem with a codak C743. I cleaned the lens casing from out outside as much as I could and sprayed a tiny bit of WD40 making sure not to get it on the lens itself.
Then I kept turning it on, and zooming in and out until I got the lens error message, switched it off, the on again, wipe, new WD40, zoom etc. repeated this s number of times until the lens was freed.
I think I had some sand/ dirt around the casing.
Worth a try I guess.
Dec 20, 2008 | Casio Exilim EXS10BK Digital Camera
Nikon Coolpix 4100
How wbout changing your batteries. mine does this if my batteries are dead.
Hope this helps
Jun 08, 2008 | Nikon Coolpix 4100 Digital Camera
Canon PowerShot SD630 LENS WONT CLOSE,LENS ERROR RESTART CAMERA
I have the same problem. How do you restart the camera. I have pulled the battery and SD card, but can't get to a menu screen to restart to camera.
Apr 16, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Cannon Power Shot SD550 Digitalelph
Sorry, missed your previous posts. The following blog outlines some simple repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty. Hope they help:
Wish you the best of luck. But keep in mind though that you have a 50/50 chance of repair with the above techniques. If they don't work, the camera likely needs replacement of the lens assembly. Unfortunately, due to the complexity of the repair (a LOT of things in the way), the cost of such a repair usually outweighs the value of the camera.
The following two links are repair guides for fixing a cracked LCD on similar SD500/600 models. They include some photos that may help illustrate how deeply buried the lens assembly is in the sd elph cameras.
http://exploded.awcr.org/DigitalCameraDisplay
http://cannonlcdrepair.blogspot.com/
Mar 07, 2008 | Canon PowerShot SD550 / IXUS 750 Digital...
Canon PowerShot SD600 Digital Camera Logo
1,252 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
