DeLonghi Pinguino PAC-700T Air Conditioner
Problem for DeLonghi Pinguino PAC-700T Air Conditioner
Unit will not blow cold air after starting up for first time this season
By wsherman on Sep 01, 2007
unit will not blow cold air....constant 72 degrees air whether set on "Fresh Zone" or Cooling". I have tried resetting the red reset button on right side of front panel..not sure if the button is working because it doesn't "click" or stay in when I push it in. Should it? When the unit cycles to "Cooling" from "FreshZone" about three minutes after I switch to "Cooling", I can hear what sounds like the compressor or something else "kicking in" but the temperature of the discharging air doesn't change..always 72 degrees. This problem occurs whether or not I have the water tank in or out of the unit. Help?
Comments:
Sep 02, 2007
- useless answer...I have one other pinguino unit that ejects air at 50 degrees until the room is cooled to about 75 degrees.My other unit, and this one, used to work fine the last time I used it in May. You obviously have no idea what you are talking about. This reply was useless. I had pretty well narrowed it down to what may be a faulty red reset button..you never addressed that.I do not want to pay for this useless "advice". I am NOT a school child and you gave a school child answer.Sorry to be so harsh, but please give value to subscribers...not a bunch of inane bs.
Sep 02, 2007
- the first answer was useless..anybody out there know what he/she is talking about?
Best Solution
posted on Sep 02, 2007
Very Helpful)
Buffalo12980
Rank: Wiz
Rating: 84%, 1078 votes
you may need to remove the rear cover to examine what is and is not running. once you remove the back, start up the unit on a workbench. see if the fan is running and the compressor has kicked in. look at the larger or two tubes coming out of the compressor. if it is cooling a small layer of frost or condensation will appear on this " suction" line. if this tubing and the other one are approx the same temperature, then there is a freon leak in the system. Only an EPA certified technician can fill your unit. I am not familiar with that RED button but it mat be a reset of some sort. With the back removed see how it is connected in the wiring circuit. if you have the wiring diagram, please send it to me under my regular email address and I'll walk you through the troubleshooting procedure.
Rating Locked! (?) wsherman has rated this solution as Very Helpful
Solution #2
posted on Sep 01, 2007
Somewhat Helpful)
Dyllan
Rank: Guru
Rating: 88%, 161 votes
That's because this unit is only designed to cool a room to approximately 75 degrees.
http://www.fixya.com/support/p114531-del...
It's not supposed to make the room cold, just comfortably cool. It automatically switches off of Cooling when it achieves this.
If you want it cooler, you'll have to get a traditional air conditioner unit (like a window unit).
Popular Solutions for DeLonghi Pinguino PAC-700T Air
Questions and Unsolved Problems for DeLonghi Pinguino PAC-700T Air
Do you recommend DeLonghi Pinguino PAC-700T Air Conditioner?
Answer
Answer
I emptied water valve at bottom which I shouldnt have to do until end of season...still water... (More)
Answer
is there something I should be doing........I don't have the manual so where can I get one...thanks
Answer
how to conect my air condittinion pinguino pca L90
Answer
Delonghi - Pinguino PAC 70 AC isn't exhausting any hot air through the back - then shuts down after... (More)
Describe your Air Conditioners problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Air Conditioner Experts
Top Air Conditioner Repairmen
in , IL
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
