Question about Kenwood KAC-7202 Car Audio Amplifier
Nothing from amp
Hi i've had this amp for a while and had it unhooked for a year almost and went to hook it back into my mustang today and getting nothing. I'hom not even sure its hooked up correctly. does it matter where those plugs go into the back of the stereo at? other than that i have the hot and ground hooked up along with the blue one. I have the blue one hooked up into the remote in the back of my stereo. NOt sure thats correct. no led unless i unhook the ground then it goes red and buzzes at me. fuzes are good. I have no idea what to look for any help will be appreciated
  • crozzey Nov 21, 2007
    ok my AMP turns on when i hook evrything up and the light turns red and then there is nothing comming out of th AMP ot the speakers so i have no idea what it is now can you help me..thanxx
  • 752 Answers
The RCA "plugs" should be in an OUTPUT of the radio (sometimes they are INPUTS, like for an MP3 player..). Go to Sears or somewhere similar and buy an inexpensive Multimeter. Set it to DC volts and place the black lead on the GND termunal of the amp. With the red lead on the BAT terminal you should read roughly 12 volts always. With the car running and radio on, place the red on the REM terminal and again you should see 12 volts. If not it's the wiring. If the voltage is 12 on both then the amp is likely damaged.
Posted on Sep 08, 2007
SOURCE:
My pyle 2200 1400 watt 2 channel amp wont get power..... why!!!!!
did you check the remote turn on wire connection at the back of stereo?
Jan 15, 2012 | Pyle Car Audio & Video
Correct ignition timing 1989 ford mustang 5.0 HO. NO computer. I put this in a 65 tang with 4 barrel carb. and some ''goodies''.
Base timing is 10 degrees I run mine around 15 and it seems to like it but if you want to get the best performance out of it start with around 14 and take it for a drive and floor it and listen for any detonation ( a slight knock ) if nothing move it up 2 degrees and do again and keep doing it once you hear it pinging alittle move it back 3 degrees and thats as good as it gets for power and remember unhook your vacuum line going to your distributor and cap it off when your setting you timing them hook it back up before you test drive it
Mar 09, 2010 | 1989 Ford Mustang
1996 mustang v6. the radio worked fine earlier
Stock headunnits are picky about the power they get, and when you are taking it to the headunit, it is putting unwanted strain on it. I can help more if I know where you put the fuse too.
Oct 10, 2009 | Car Audio & Video
Last summer closed up grill had no problems..today not working
unhook the tank and hook it up again being sure that the regulator is right side u p.
these new grills have a safety valve that often partially closes and causes problems.
Apr 27, 2009 | Brinkmann Charmglow 810-7400-S Propane...
I have a power acoustik ps2-2600 it went out this morning the red light was on i checked the ground it was fine when i unhook the remote or the audio cables it turns off if i hook up the audio alone it...
unhook all the cables including power let sit for 15 minutes and than hook up the ground rca cables remote and than power in that order with the car off and the battery unhooked that hook the battery up the amp went to protect mode to keep it from blowing i hope your amp isnt like some that only the factory can reset most amps arent and reset themselves
Apr 20, 2009 | Car Audio & Video
P3002 protect light problem
sounds like u have shorted opt transistors no big deal goto nte electronics.com and replace . these amps r known 4 postive switching regulators going bad 3$ part rep[lace the #sholud be like tl 494cn square 14 pin blk long hopes this help u later dude
Mar 17, 2009 | Car Audio & Video
Amp won't turn back on, all fuses fine, all connections good
that sounds like the amp might have a bad ground.
Mar 15, 2009 | Kenwood Car Audio & Video
Aztek will not start.
First check if battery if it is charge and try again ,or use one that have full charge.
If works you alternater is not charging,
Can also check alternater by pulling ground cable off wile car is running and if stops running change you alternater.
Feb 15, 2009 | 2001 Pontiac Aztek
Fisher ca 9025 amplifier
The amp is in protect mode. Something in the final stage is defective. This is usually caused by shorted output transistors. This unit is worth getting repaired. Expect a parts cost in the $25-$50 range.
Dan
Dec 03, 2008 | Audio Players & Recorders
2005 ford mustange with dead guages
the instrument cluster needs repair, the steppers on the motor need upgrade nothing else or buy a new instrument cluster
Nov 22, 2008 | 2005 Ford Mustang
Kenwood KAC-7202 Car Audio Amplifier Logo
74 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
