Question about Dual XD-7500 CD Player
Car head unit cdplayer/radio
I connected my xd7500 head unit and i have a problem. When i go to turn it on (pwr button) i get nothing. But when i press the eject button it will open up and recieve cd's. How do i get it so i have power to the whole unit? the wires are connected right. Please help me.
    Scholar:
  • 98 Answers
Hi. You need to check a few things. make sure you have power on both the red and yellow wire with the key on. If only one has power the radio will not work. also make sure that you have a good ground connection on the black wire.. if nothing works yes you probhably have a bad radio. the dual brand radios are notorious for poor solder connections on the mainboard due to the way they build thier cheap circuit boards..
Posted on Sep 05, 2007
SOURCE:
Unit has power and lights up. None of the buttons work and cd wont eject. The CD eject button turns the unit off but won't eject the CD. Cannot change the functions. Have reset the unit and checked th
Remove the face plate and clean the contacts on both the head and the radio. It sounds like a bad connection, The base and head use serial data to talk to each other(control).If one of these connections are bad the unit will not work properly.
Oct 06, 2014 | Sony MEX-BT2900 Bluetooth Car Stereo with...
Cd player sounds like it is fast forwarding
Sounds like you have two diff connections hooked together
Sep 03, 2012 | Sirius Satellite Radio Receiver
I have a Sony Cdx-gt300. When the head unit receives power it turns on, the clock shows, and then the Radio functions scroll continuously. The radio has been reset a dozen times at least. I have also...
you might have a button stuck, try gently pulling the function button out a little bit. i used a sheet rock knife razor blade and was able to release it but after pressing the function button again it started all over again. good luck.
Mar 26, 2017 | Sony CDX-GT300 CD Player
276C not locating any sats
Going to give you a possible solution but i don't think you are going to like it. The problem sounds easy and being as the unit is way off warranty you may or may not want to try this. Sounds like what you have is a broken wire in the antenna or a bad connection, you might MIGHT be able to fix this by opening up the antennae portion of the unit and see what you can see, broken wire or bad connection will have that result. Cleaning of the connector or re soldering of the wire should/might fix the problem. Hope this helps
May 10, 2010 | Garmin GPSMAP 276C GPS Receiver
My dual xd7500 cd player doesnt turn on anymore while hooked up only the power button light turns on nothing else works this is hooked up in my bedroom but the problem should be the same as in car can...
Is the red wire in the back hooked up to a power source? You will need that in order for it to turn on. It is the wire tells the radio to turn on when you turn your key.
Oct 18, 2009 | Dual XD-7500 CD Player
Who do i take off my face on my dual xd7500
when the radio face is open like it is in the picture above... take a look /feel directly underneath (back side of the lower controls)the large center knob. you are going to feel a push button about an inch wide. push while pulling down and toward you to remove. the until will then close on it own. reattach by clipping directly on once unit has closed
Aug 15, 2009 | Dual XD-7500 CD Player
Swap radio
It should as they are Both Double Din Units. The Larger Head Units from GM.
Jan 22, 2009 | 2001 Chevrolet Impala
CDs and Ipod wont play with Alpine CDA-9885
The Alpine has two tigger wires when it turns on. One is an AMP TURN ON wire (blue/white) and a PWR ANT wire (blue) and that wire only comes on when using the radio or an optional HD radio unit ... When it was installed/connected . someone hooked your amp turn on wires for your "full range amps" to the PWR ANT wire. And the sub amp trigger is either hooked correctly to the AMP TURN ON WIRE or somewhere else, it probably shouldn't be... Check it. Amp triggers should all be to the blue/white wire from your alpine. Warning: Alpine trigger wires, are very easy to mess up they supply a very limited amount of power.
Apr 28, 2008 | Alpine CDA-9885 CD Player
Power on problem for XD7500
Hi. You need to check a few things. make sure you have power on both the red and yellow wire with the key on. If only one has power the radio will not work. If the red and yellow wires are switched it can also affect the way the redio operates. One is constant power for memory the other is key on power so the radio knows to shut off with the ignition key off. also make sure that you have a good ground connection on the black wire.. if nothing works yes you probhably have a bad radio. the dual brand radios are notorious for poor solder connections on the mainboard due to the way they build thier cheap circuit boards..
Aug 02, 2007 | Dual XD-7500 CD Player
Dual XD-7500 CD Player Logo
182 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Mike Duncan
Mike Duncan
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
