Question about Tomtom GO 300 GPS Receiver
TomTom Vehicle Interface Box
I went to have this item installed and the guy DID NOT know what he was doing. He cut all the ends off of the harness. I need the schmatic of the box so that I can get it installed properly.
    Scholar:
  • 143 Answers
Make sure you tell them the make & model of the vehicle.
the right interface should be supplied so no choping & changeing needed.
Posted on Dec 15, 2007
Radio pro 4 wiring
You should purchase a radio harness for your car, and it's wires will connect to wires of the same color from your JVC radio harness. Join the two harnesses together (solder, crimp caps, barrel connectors, etc.) and then one end plugs into your JVC, the other end plugs into the factory harness that the original radio was connected to. If for some reason, your factory harness plug has been cut, you'll have to hardwire the JVC harness. I've included a link to the wiring diagram for your car. The steering wheel controls are moot; they will not work unless you've got some aftermarket adapter that allows them to interface with the JVC radio.
2004 pontiac grand prix speaker wiring diagram Google Search
If you need further help, I’m available over the phone at https://www.6ya.com/expert/reginald_bec291de192ca44f
Nov 13, 2017 | Car Audio & Video
I HAVE A F900BT WILL IT FIT IN MY 2010 CHEVY TRAVERSE? AND IS IT ALL PLUG & PLAY
It will fit, but the parts are expensive and it is not plug and play.
Parts needed:
Dash kit- Metra 99-3305 About $15-$20
Antenna adapter- Metra 40-CR10 (Chrysler antenna adapter) Yes GM uses Chrysler parts. About $10-$15
Wire harness/Interface- GMOS-LAN-01 (non bose or onstar) About $100
GMOS-LAN-02 (bose/onstar) About $120
The reason for the pricey harness is to retain data features on the vehicle and to interface with Onstar (GMOS02).
This is the right way so don't cut corners because it can cause issues on your brand new vehicle.
All of your safety chimes run through the stereo and not using the correct interface can cause issues with your gauges
www.metraonline.com or www.scosche.com are good sources for install parts info
May 14, 2010 | Pioneer AVIC-F900BT Car GPS Receiver
My radio harness was cut and tring to install cd
okay you will need to hard wire it in the vehicle. so i will need to know what year make and model car you have?
Jan 31, 2010 | Clarion DXZ645MP CD Player
Tried to attach to computer to update since then all I get when turning it on is a flashing red cross and can not soft reset
Since you have said that your TomTom is only displaying a flashing cross (or "X"), it is because the TomTom application is not installed or can not be found. This usually happenes when you attempt to update your unit and it is interrupted (i.e., not properly disconnected from the computer, the TomTom was underpowered by using a USB port on your monitor/keyboard, or lost power during the update. In fact, it might just be pissy.)
Down to how to fix it: You essentially just need to reinstall the application.
1. Soft reset (I know you have already done this but am providing a link just in case: http://uk.support.tomtom.com/cgi-bin/tomtom_uk.cfg/php/enduser/popup_adp.php?&p_faqid=6965)
2. Connect you’re GPS unit to your computer
3. Press the power button for about 5 seconds and the TomTom Home will start.
NOTE: It is highly recommended that you use TomTom HOME to make a backup. You can find out how to do this here: http://uk.support.tomtom.com/cgi-bin/tomtom_uk.cfg/php/enduser/std_adp.php?p_faqid=3171&Lid=1
4. Delete application files (so we can do a clean install), to do this:
- in HOME, click "MANAGE MY NAVIGATION DEVICE"
- Select the ITEMS ON DEVICE tab and tick the box by "APPLICATIONS".
- Then click REMOVE ITEMS FROM DEVICE
- A warning will pop-up, click "OK"
- Select the ITEMS ON COMPUTER tab and tick the box by APPLICATIONS
- Then click REMOVE ITEMS FROM COMPUTER
- Another warning will pop-up, click "OK"
5. Reinstall the TomTom Application by clicking UPDATE MY DEVICE
- Then click UPDATE AND INSTALL
- Once done, click DEVICE > DISCONNECT DEVICE
6. Next, we're going to run the TomTom Clear Flash Tool (the downloads include step-by-step directions for clearing the flash)
- for windows: http://www.tomtom.com/updates/clear_flash/clear_flash.exe
- for mac: http://www.tomtom.com/updates/clear_flash/clear_flash.dmg
7. Safely disconnect.
- on windows: click the SAFELY REMOVE HARDWARE ICON (a icon with a green arrow that is hanging out in the system tray and then choose "USB MASS STORAGE DEVICE" from the pop-up
-on a mac: drag the desktop icon of your device to your trash.
8. Your device should start up automatically. If it hasn't within 10-15 seconds, press the on/off button.
You're done!
If by chance this still doesn’t work, you can try formatting the internal memory or memory card of your TomTom. If you need a link or directions, simply send me a message or reply!
Hope this helps!
-TJ
Jan 25, 2010 | Tomtom ONE XL GPS
TomTom XL stuck on front screen, how do I reset it
You're done!
Hope this helps!
-TJ
Dec 27, 2009 | Tomtom GPS
Last june we tried to update our tomtom that was
If you have an SD card installed then
Remove the SD card from the tomtom
Try the hard reset.
Push a Paper clip in the tiny hole by the card slot.
Push it in firmly whilst the unit is powered up (not too hard) for about 3 seconds then release.
You may have to power down and then up again and even hold down the power button a little longer the first time you do this.
That would normally reset the tomtom.
If it does then get the latest version of TOMTOM HOME
Install it and run the program.
Now with your GPS tunred off connect it to your computer via a short USB lead.
TTH will now start up and from there you can update the tomtom itself.
If you are getting a red cross whilst bootng the GPS then
The card may need to be formatted properly first or re-formatted.
Formatting is better done in a card reader.
There are differing views but this method has always worked for me.
Insert the card in the reader,. Using my computer or windows explorer
right click on it and select format
select FAT32 as the files system
Now connect the tomtom to the pc but don't let tomtom home run.
Exit TomTom Home if need be.
You now need to select your tom tom which will also show as a drive and may even show its own special icon.
In windows explorer select tools then folder options.
Click view and tick the box for "show hidden files and folders"
It may warn you but you can ignore it.
then just copy ALL the files from the tom tom to your sd card.
DO NOT USE CUT AND PASTE !
Sep 09, 2009 | Tomtom GO 720 GPS Receiver
Wireing in car stereo accord 2006
good morning and welcome to fixya.
are you installing the factory radio or an aftermarket radio? you can purchase a wire harness for this vehicle that will plug into the factory chassis harness without cutting the harness connector. if your connector is missing the wires in the aftermarket harness are color coded the same as the wires on the factory side. check best buy or crutchfield.com those guys at crutchfield are really great. good luck and let me know if i can help anymore. thank you
please don't forget to rate this solution
Mar 13, 2009 | 2006 Honda Accord
T-harness does not fit remote start unit
If the ends don't fit in to your remote start unit you will have to cut them and splice into them, or if you mail me both harnesses I will do it for you for free, you would have to pay for me to ship it back to you of course but I think you could do it your self or if you know someone who knows how to solder
Jan 29, 2009 | Bulldog Remote Starter & T-Harness Kit for...
95 ford probe wiring harness. no sound but turns on
Hey I cant help you with your problem but can you help me? i have a 95 ford probe with a metal ended square harness on it, i went to canadian tire 100 times looking for the right harness and none fit it. a couple months later I had found another harness connector a few inches don't from the other square one.Now before i found that one i cut the harness and tried manually connecting them to the new radio. The radio would turn on but now sound would play.... and i tired 9 colour codes still nothing. if you have any idea about my problem it would be much appreciated thanks.
Jun 25, 2008 | Car Audio & Video
Tomtom GO 300 GPS Receiver Logo
80 people viewed this question
Top Tomtom GPS Experts
k24674
Marvin
Marvin
Archie Ferrarini
Archie Ferrarini
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
