Question about KitchenAid KUDS01FKSS Dishwasher
KUDS01FKSS dishwasher not cleaning
I have the KUDS01FKSS dishwasher from kitchenaid and it does not nor has it ever cleaned the dishes well. I have tried loading it in several different ways. My old dishewaher always worked just fine so I don't see how it could be a water pressure or hard water problem. i really think this dishwasher just sucks! However I don't think Kitchenaid will stand behind their product from the different negative reviews I have read. Any suggestions on how to deal with the company to get good results and be a happy consumer in the end?
  • 248 Answers
Re: KUDS01FKSS dishwasher not cleaning
One thing to check is soap usage. Newer dishwashers use less water and require less soap. Too much soap will redeposit on dishes. Try halving soap usage. Also run hot water in sink until it gets hot before running dishwasher. I have a Whirlpool. Same thing. Works great. If your water is hard add more detergent.
Posted on Oct 07, 2007
0 characters
3 Points
Water fills and cycles fine. Arms do not spin; no cleaning. Circulation motor?
Either the motor or chopper is broken. If chopper is broken the screen will be clogged with food. If its clgged you can clean it and reinstall and see if theres any improvement. If so replace chopper.
Sep 26, 2011 | KitchenAid KUDS01FKSS Dishwasher
Clean light keeps flashing
This is due to a fault with the water heating properly. See the attached link to reset the control and reasons why this failure occurred.
Flashing Clean Light
May 30, 2010 | KitchenAid KUDS01FKSS Dishwasher
Dishwasher doesn't rinse all of soap off of dishes--especially on upper rack.
check the spray arms for free rotation. Clean the jet holes if they are clogged.
May 23, 2010 | KitchenAid KUDS01FKSS Dishwasher
How do I clean the KitchenAid 24 in. KUDI01FLSS? I can't wash dishes until it's cleaned.
Use 1-2 packets lemon kool-aid (unsweeted of course) and run it with no dishes in it.
The citric acid will dissovle most gunk
Oct 20, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
The dishes on the top rack are not coming clean
check top spray arm to make sure all of the spray hole are clear
Oct 09, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
KITCHENAID dishwasher will not dry the dishes
kitchen aid mod kud101dl does not clean dishes well. lot of scum on door.
Feb 26, 2009 | KitchenAid Dishwashers
Check your spray arm that nothing got stuck in its holes. make sure the spray arm is turning all the time when using the machine :
put the spray arm in 90 degree position, turn the unit on , check that the spray arm move...
make sure your seal of the door is clean and nothing prevent it to close evenly the door...
good luck 911servicetoday . com
Jun 19, 2008 | KitchenAid KUDS01FKSS Dishwasher
KitchenAid KUDS01FKSS Dishwasher Logo
388 people viewed this question
Top KitchenAid Dishwashers Experts
Mike Cairns
Mike Cairns
Carmen Mikulic
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
