Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Error message F04
When trying to dry the clothes error code F04 shows, and the machine stops working, what does this mean?
  • Anonymous Apr 27, 2009
    Hotpoint washer/dryer WD640 1400 spin.
    I set my machine to wash and then dry over night, when i come down in the morning the error code F-04 is flashing on the display, and the sheets/towels are hot but still wet.
    If i put the WASHING machine on again, all works fine.
    Any solutions as this is driving me crackers!!!
    Thank you.
  • 183 Answers
FO4 indicates a pump fault.
Posted on Sep 01, 2007
  • Karel Funda
    Karel Funda Jun 27, 2014
    clean pump filter - on the bottom of waher - behind white case
My brother NX-600 keeps displaying the code F04, if I switch machine off then on again it will allow me to sew, but then stops showing the F04 message agai.
You need to find out what that particular error code means and address that particular issue. It could be something very simple but frustrating, just the same..
Search for:
Make Model error code F04
Oct 19, 2017 | Brother Sewing Machines
Tip
Wet cloths or error F04
I could not find anything on the internet above this error, the reason for this.
Machine runs fine and completes the cycle with no error, but with 1 fault, cloths are still wet. just once it showed error F04.
I noticed that:-
1. the drum did not spin fast
2. water was draining out of the outlet pipe but at a slow rate
Fix:-
water pump access at the bottom right of the machine was blocked with coins and a plastic strip, cleaned and all working again.
Did not expect the pump to be the fault as water was coming out the outlet pipe.
on Jun 05, 2018 | Whirlpool Washing Machines
My Brother SE-270D shows error F04 in screen
http://www.sewingmachinesplus.com/brother-sewing-machine-error-codes.php
Sep 11, 2016 | Brother SE-270D Computerized Sewing...
Brother NX-400. Never used. Error F04. I've looked for a model # for the foot for NX-400 to no avail. The foot that came in the box is Model T/FC-322. I can't help but think this is the wrong foot.
If you mean the foot controller, then the T/FC-322 is a substitute that should work. It's listed as a replacement here: http://www.sewingmachinesplus.com/234522001.php . The manual for the NX400 gives the foot controller as XC1154-051 . Brother changes the part number often but the wiring remains the same. Another substitute controller is available here: http://www.sewingpartsonline.com/foot-control-w-cord-brother-xc6651121.aspx .
The F04 message may mean there is an internal failure. This probably needs to be fixed by a Brother authorized repair person.
I wish that I had better news for you.
Mar 13, 2016 | Brother Sewing Machines
I have a Panasonic NV-VP60GL, it has repeatedly come up with error code f04. From what I've been advised this is to do with the loading motor. I replaced said motor and still get problem. Help please?
F04 actually just means the mechanism locks during unload. The load motor can indeed cause this, but it can be working fine, but the timing might be out. This could be something to do with the mechanical parts of the mechanism. You should examine it for broken or worn plastic parts.
Mar 19, 2015 | Panasonic Televison & Video
My machine shows FO4 message and none of the buttons are working for this message.
There are 2 things that cause the F04 error.
1 - Wrong foot control: If you have 2 machines, you might have them mixed up between machines.
2 - Burned out foot control.
Bring the machine to a Brother shop; try the new foot control on your machine before you buy it.
The part number is XC7290051
Alternative Part Numbers Include XC6651321, XC6651221, XC6651121, XA3931051, XC1154051 & XC6651051
Apr 16, 2012 | Brother SE-270D Computerized Sewing...
AEG OKO Lavamat Update washing machine LAVALOGIC 1600
This error code (C3) means your water sensor has detected a leak. it will stop when the sensor is dry.
Try getting the water out of the trap door and letting the machine dry.
I would also unplug it for secirity reasons.
Basically your water pump is getting tired or the sensor is dirty. Try cleaning the sensor or else you may have to change the pump.
Good Luck!!
Dec 10, 2007 | AEG L86800 Front Load Washer
Error F04 message displayed
Panasonic K deck F03 or F04 shows in display check loading motor coupling pt no VDP1434 or motor pt no VID12128 £11.95 CHS
Nov 22, 2006 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
2,443 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
