Question about Brother HL 5250DN Laser Printer
Brother HL-5250DN Toner indicator light remains on after replacing toner, this is not the first time, getting tired of taking it to the service depot everytime, anything I can do myself...........is this a common problem???
  • 2 more comments
  • Pammmm Mar 11, 2008
    Was suprised two cartridges ago when I installed a new cartridge from a box I had opened & got a toner-out message so quickly. Had accumulated a couple toner units to recycle & thought I maybe I turned in my good one in place of the empty. Bought another cartridge. Noticed the toner light flickering almost right away. But it printed, so I figured the machine must be cycling the toner between print jobs. Now I'm getting a toner-out msg WAY sooner than in the past. Is there a toner sensor we can clean? When you took your printer to the shop, what did they say the problem was? Either the ability of the printer to communicate with the toner chip or whatever is severely degrading over time or the quality of the cartridges is slipping, or so it seems to me.
  • Anonymous Dec 01, 2008
    I have the same problem - the LED of Toner is keeping on. it does't go off after replace with a new toner.
  • Anonymous Dec 03, 2008
    My toner is only a month old, I've had my printer for only 3 months and toner light goes on constantly! Help please!
  • Anonymous Dec 04, 2008
    Printech's on good drugs. There's no button there.
    New Friend:
  • 159 Answers
If the Drum LED is still lit after replacing the drum unit, the Drum counter may not be reset.
Reset the Drum counter as follows:
  1. Open the front cover.
  2. Locate the control panel button under the LED lights on the left side.
  3. Press the control panel button until all lights are lit, then release it.
    The Drum counter is now reset.
Posted on Mar 27, 2008
I have a brother 5250dn printer that's on strike right now. At first it wouldn't print indicating a drum problem. We addressed that issue by resetting the drum counter (took out the toner/drum and held...
Try this.... no guarantees but I have seen this work.
1: Turn off power and remove toner/drum
2: Tape the little spring loaded lever just inside the printer on the upper left hand side in the *DOWN* position! Do not replace drum yet and...
3: Turn power on to printer and let it cycle. Status/Toner lights will come on as usual.
4: Turn off printer, remove tape from lever, replace drum and turn back on.
Jan 19, 2011 | Brother HL 5250DN Laser Printer
Drum light is blinking and not sure how to change it or fix it in Brother HL-5250DN
Hit the purple/blue button on the top of the printer 3 times. This will print a settings report of the printer showing you the toner levels and the drum life.
If you need a new drum purchase one. (I would suggest a new printer at this time but if you like it continue on)
Open the front of the printer and pull out the toner and the drum cartridge. The drum is on the bottom of the toner. Disconnect the drum from the toner and connect the new drum. Replace the toner/drum and you are good to go.
Nov 15, 2010 | Brother HL 5250DN Laser Printer
I've installed a new drum AND a new toner cartridge. have followed all directions to reset the drum and the light still flashes and I can't print, this is for a brother HL-5250DN printer
Try this....
Jul 20, 2010 | Brother HL 5250DN Laser Printer
Brother HL-5250DN Laser Printer TONER LIGHT ON & NO PRIN PAGE
When the toner light is on this means the toner is empty and needs to be replaced before it can print again. Replace the toner and you will be able to print again.
Jun 05, 2010 | Brother HL 5250DN Laser Printer
Brother HL-5250 printer toner Light on but Cartridge has Toner it
Try this....
Mar 08, 2010 | Brother HL 5250DN Laser Printer
Brother 5250dn and all light are blinking
That series of lights indicates a main circuit board failure. You will need a shop to replace the main logic PCB. Could be caused by anything, static shock, bad input power from power strip or power failure, just plain CPU failure. If it's under warranty, 1 year since purchase, you need a Brother service center, out of warranty a new printer would cost less than repair.
Feb 02, 2010 | Brother HL 5250DN Laser Printer
Brother Printer HL 5250DN
A solid red STATUS light with a solid yellow TONER light indicates toner out...replace according to pg. 63 in the manual.
It can also indicate a cartridge position error. Take the DRUM UNIT out of the machine and re-install.
A solid red STATUS light only means:
Front cover open
Fuser cover open
Dust on drum
Too many trays
Buffer error
Print overrun
Memory full
Download full
Font full
See pg.48 ofthe manual.
Oct 02, 2009 | Sport & Outdoor - Others
Replaced toner cartridge and light stays on the printer will not
how do i set the toner reset lever on a brother hl 5250 printer
Mar 31, 2009 | Brother HL 5250DN Laser Printer
My broher 5250DN keeps showing toner needed, but i've replaced it
I just had the same problem. We have several of these in our office, but switching toner cartridges made no difference. Then I saw this site: http://www.oasis-imaging.com/images/pdf/cart_inst/TN580.pdf
I did steps 14-16, which takes 5-10 minutes. I put the toner back in the printer, turned it on, and it works perfectly now. Give that a try!
Feb 05, 2009 | Brother HL 5250DN Laser Printer
Brother HL 5250DN Laser Printer Logo
1,944 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
