Timer light continues to flash want power up tried system reset and unplug and still no sucess
Good Day, rstoes01;
Most common problem with TV is the following. The underline is the problem 99.9% of the time.
LED does not stop blinking after plug in. Verify the standby supplies, 12-volts at connector KA pin 17, 6-volts at KA pin 18 and the 28-volts at KA pin 19, if the supplies are present suspect the DM PCB part # 934C067001 4. LED does not stop blinking after plug in. Check C9B01, C9B02, C9B10, and C9B11 (1000 UFD 16) on the DM PCB, replace them with part # 181P734030 (680 UFD 16 V).
Good luck, big IRISH.
