SOURCE: 1990 ford f150 cross over valve location
Please Help ME by Remembering to RATE ME Thank you Vrey Much !!!
This vehicle does not use an external fuel tank switching valve. A supply check valve in the fuel pump assembly opens when the outlet pressure from the energized fuel pump exceeds the opposing check valve spring force.
R E C A L L 1991
THE DUAL FUEL TANK SELECTOR VALVE MAY MALFUNCTION AND CAUSE AN OVERFILL CONDITION IN ONE OF THE FUEL TANKS, RESULTING IN AN OVERFLOW OF FUEL PAST THE FILLER CAP.
THE OVERFLOW OF FUEL PAST THE FILLER CAP CAUSES A FUEL LEAKAGE, WHICH CAN RESULT IN A FIRE WHEN EXPOSED TO A SOURCE OF IGNITION.
REPLACE THE DUAL FUEL TANK SELECTOR VALVE.
SYSTEM: FUEL TANK, AUXILIARY.
VANS AND LIGHT TRUCKS WITH DUAL FUEL TANKS PRODUCED IN THE FOLLOWING PERIODS: F150, F250, AND F350 LIGHT TRUCKS BUILT BETWEEN FEBRUARY 28, 1989 AND JULY, 1989; ECONOLINE BUILT BETWEEN FEBRUARY 28, 1989 AND FEBRUARY 11, 1991.
NOTE: FORD HAS AGREED TO RECALL THESE VEHICLES BUT PARTS ARE NOT YET AVAILABLE.PARTS WILL BE AVAILABLE IN DECEMBER 1991. YOU WILL RECEIVE A LETTER FROM FORD ADVISING YOU WHEN TO SCHEDULE AN APPOINTMENT WITH YOUR DEALER TO HAVE THE RECALL WORK PERFORMED. IN THE MEAN TIME, YOU CAN TAKE THE FOLLOWING PRECAUTIONS:FILL EACH TANK TO ONLY 1/3 FULL. IF YOUR VEHICLE LEAKS FUEL OR IF YOU SMELL FUEL, STOP USING THE VEHICLE AND CALL FORD AT (313) 446-4654 AND ADVISE THEM OF YOUR PROBLEM. REFER TO FORD SAFETY RECALL NUMBER 91S39. AN OPERATOR WILL TAKE YOUR NAME AND TELEPHONE NUMBER. A FORD REPRESENTATIVE WILL CALL YOU BACK
SOURCE: my 89 ford f150 v8 302 wont start up i
U are going to have to replace the fuel pump, the pump is located in the fuel tank.
SOURCE: I have 1990 Ford F150 with 2 gas tanks.Electric
check fuel relay under the hood..it may be blown..look in owners manual for relay location.
