Question about Sony CDX-M7810 CD Player
Broken wiring harness
I broke the wiring harness that goes into the back of the car stereo and am not sure where to find a new one. I looked through the manual and there is no parts list or manufacturer phone number. Any ideas? Thanks!
    Scholar:
  • 98 Answers
Ive had pretty good luck finding them on ebay. also a good reputable stereo shop should be able to help you out.
Posted on Sep 01, 2007
SOURCE:
We got an aftermarket stereo for our 2001 Volvo s60 an got the wrong wiring harness so we cut into the stock harness to put the new stereo in an now the driver door has no power and all the electrical on...
Hi Kacie.
Pretty much the only thing to do is remove the harness you spliced into the incorrect harness and use crimp connectors (the GOOD ones, not those cheap plastic blue ones) to match wire-for-wire and restore the original circuitry. THEN have at the correct harness and reinstall the stereo wiring. It's a PITA all right, but it really is the best way to fix your problem.
Sorry about the bad news...
-Steve
Nov 13, 2014 | 2001 Volvo S60
Wiring harness
your choices are replace harness (you can take one out of car in junk yard)or buy new.Or fix broken wires by sodering and shink wrap, or using but end conectors If this was helpful please leave me good feed back
Jun 28, 2013 | 1997 Chevrolet Cavalier
Did I short out my kenwood in-car stereo?
To be honest if you have taken it apart then it is fried and the circuit board is not easy to replace i recommend a new radio, next time run your usb wire loose as you can so it wont never snag
May 29, 2013 | Kenwood Car Audio & Video
Please Help I Need A 1992 Mercury Capri XR2 color-coded Stereo Wire Harness Diagram
Go to your local auto store and get the Hanes auto manual for this care and they should have a wiring schematic for you to follow also you can look your new stereo up on the web and find out what each colored wire goes to what!!! Good luck
Jun 07, 2012 | Lincoln Cars & Trucks
How to remove 2001 hyndai sonata audio system
Instructions
Things You'll Need:
  • Screwdrivers
  • Wiring harness adaptor
  • Hyundai radio adaptor kit
  1. Open the coin holder and remove the two screws at the front. Pry the trim from around the gearshift lever and unhook the power wire to the cigarette lighter.
  2. Locate and remove the two screws from the bottom of the radio trim panel. Look for the screws, attached to a rod, below the glove box. Unhook the cable from the rod and pull the rod free.
  3. Place the shifter into "D" and slide the radio trim panel away from the dash. Locate the four screws at the front and sides of the stereo and remove them.
  4. Pull the stereo out of the Hyundai Sonata dash and disconnect the wires from the back of the unit. Connect the wiring harness adaptor to the original harness.
  5. Slide the new head unit into the Hyundai radio adaptor kit. Attach the wiring harness adaptor and antenna wire to the back of the new head unit and push the entire assembly into the dash.
  6. Secure the stereo in place with the four front and side screws and turn it on. Verify all of the speakers and features are working. Reattach the radio trim panel, insert the rod back into cable assembly and secure the trim around the gear shift.
In here you can find tips about remove radio...
- Hyundai Car Stereo removal
- Stereo Removal Hyundai (buy)
I really hope help you with this (remember rated this help). Good luck.
Oct 01, 2009 | 2001 Hyundai Sonata
I need a wiring diagram for the aiwa stereo harness.
I would like to see a plug for a aiwa car stereo
Mar 30, 2009 | Aiwa CDC-X207 CD Player
What are the two plugs on the back of the factory radio
Power for memory, power when key on or accesories,etc, then all the speaker wires. Have you stopped at a stereo sales place, or autoparts place and asked for an adapter harness to go from your vehicle to an aftermarket stereo? It will make it much easier, much cleaner in case of removal later & will probably save a big headache too.
Mar 14, 2009 | 2005 Toyota Camry Solara
Installing after market stereo
Dave,
You will need to go buy a wiring harness adapter from your local Walmart (usually cheapest there) or Local Electronics place (ie Best Buy). The wire harness that goes out from the radio goes into the Adapter and the adapter plugs into the car harnesses. Also these Adapters come with the wiring diagrams for your vehicle. They typically run 10 - 15 bucks depending on where you get them. Thanks for using FixYa!
Sincerely,
JC
Nov 21, 2008 | 2000 Pontiac Grand Prix
I do not know which wire goes to what on this pioneer car stereo
First, make sure you have the right plug in your radio, does it look right? if it does, than buy a wire harness for your particular vehicle from best buy, circuit city, or any stereo shop, this will connect to the plug in the back of your pioneer, making sure you seal up all the connections between wires. The package the purchased wiring harness came in will have coresponding colors and locations for each wire, and the wires themselves might be printed the same way. Its not too hard, just be sure to wire'em up correctly. good luck
Aug 12, 2008 | Car Audio & Video
Wire harness diagram
www.scosche.com will give you the cars wires, u may want to just by a harness adapter, cutting wires=bad
Don
Nov 21, 2007 | JVC KD-S680 CD Player
Sony CDX-M7810 CD Player Logo
203 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Mike Duncan
Mike Duncan
Dalynn Turner
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
