Question about Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television
Burnt spot on lower portion of tv screen
Pananasonic hdtv model number pt53tw53g was just moved and has a burnt spot on the screen. Any suggestions?
    Sergeant:
    Champion:
  • 375 Answers
Try to pin point which crt is at fault if it is image burd ,by covering eash crt and viewing the sereen
Posted on Sep 07, 2007
One yellow, one pink, and one blue spots appeared on my tv screen.
The set if projection which model here is, has arced and now each of the three picture tubes used has a tiny permanent burn mark on its screen.
That is what you are seeing, the set uses three picture tubes with screens like the old tv sets===the coating has been burnt in each, want to prove it, remove rear cover and cover any one of the three lens and that mark on one tube will go a way.
Not fixable.
Dec 23, 2012 | Mitsubishi WS-55315 55" Rear Projection...
Blue spots on Sony WEGA KDF60XS955
Thats caused by a bad optical block. The cost of that repair will almost always be greater than replacing the TV.Thats a very common issue with alot of Sony DLP models which suffered that optical block issue with the blobs of color usually blue or green
Dec 10, 2012 | Sony Grand WEGA KF50WE610 50" Rear...
Colored spots on Samsung HLP5063W
The color wheel or the DLP chip itself will cause this. Parts can be had here: www.shopjimmy.com
Jun 27, 2017 | Samsung HL-P5063W 50" Rear Projection HDTV
I have a 52" LCD
Can you still see the spot when the TV is off? In any event, the screen may have something on it or the mirror that reflects the image from the projector where the bulb is. Make sure the projector bulbs are clean. Good luck, thanks for using FixYa.
Mar 03, 2011 | Zenith E44W46LCD 44" Rear Projection...
When background is white I can see colored spots on upper portion of screen.
Light Engine- Goole to this website and type in your Model number Encompass Parts Distribution
You can also Call UED for rebuilt Light Engine 1-800-648-6657
Jul 02, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
Blue spot on screen
  1. First, look for the source of the problem. Large speakers, especially older ones, are the most common offenders. Notice the position of the blue spot on the screen (left, right, upper, lower, etc.) for an indication of which direction the magnetic field is coming from.
  2. If you think you have determined the source of the magnetic field, try moving the object away from the television screen. If this does not work, continue looking for other potential causes.
  3. f you are unable to determine what is causing the magnetic field, try moving the television. Sometimes magnetic interference can come from a neighbor's equipment, especially in apartments and condos. Moving the television to another part of the room, away from shared walls, may help.
  4. If none of these techniques succeeds in removing or improving the appearance of the blue spot, try to find if their is any demagnetizing coil button available in front of the TV panel , it may be symbol like magnet and a diagonal line on it
Please Rate it
Sep 05, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Picture went funny on my PT-47WX53 last night... a blue ghost like arc appeared mirroring the lower portion of the images displayed on the tv a few inches above where they were positioned. Most of the...
You need to replace convergence ICs in TV for correct converge picture.
Below is an image of D board and ICs are marked need to replaced.
If you are familiar with TV repair and knows basic electronics then can do this job OR call TV tech to fix it.
Jan 29, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Where to find discontinued board
go to this link and on the lower left side click on the contact link and leave the board number and they will respond right away that have access to rebuilt as well as new boards for all models and all boards rebuilt are guaranteed.
http://servicemanuals.vstore.ca/
Apr 07, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Open Questions:
Has anyone had problems with connecting an 'HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input,HDMI+ Audio output)' to a Panasonic PT-53TW53? I have a TiVo Premiere hooked up to my Panasonic PT-53TW53. I use the HDMI out, and RCA R+L outputs on the TiVo, and hook up to the digital in connections on the TV. The conversion of the HDMI out is via an HDMI to DVI cable. This has worked perfectly for years, but recently I wanted to disconnect the TiVo and replace with my Roku or Amazon Fire TV. Both have a single HDMI output. So I purchased an AGPtek HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input, HDMI+ Audio output) box, hooking up the HDMI output from the Roku or Fire TV to the input on the extractor/converter, and simply disconnecting the HDMI to DVI and RCA R+L outputs from the TiVo, and plugging them into the outputs on the converter/extractor. The converter/extractor has a 3 position switch: PASS, 2CH audio, or 5.1CH (via and SPDIF or Toslink cable). I have had 2 of these converter/extractors, and with both the Roku and Fire TV I got the same results with both converter/extractors: With the switch on 2CH, which is where I understand I should get HDMI video and 2CH RCA audio, all I get is the RCA audio. No video. If I switch to PASS I get video with no audio. Of course on the 5.1 setting I get nothing, since the TV does not support SPDIF. Yet I see reviews all over Amazon indicating folks are using this converter/extractor for this very purpose, and it is working fine. I can't possibly imagine that it is some sort of incompatibility issue with the TV, since the TiVo has worked (and continues to) fine for years. Any ideas?
Feb 28, 2017 | Panasonic PT-53TW53 53" Rear Projection...
See all Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Questions
Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television Logo
46 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
