Question about Refrigerators
Refrigrator power went out, when back the water and ice doesn't come out
Could be you water water VALVE behind refrig. water line is hooked into it... check with ohm meter
Posted on Sep 02, 2007
Driping of water from top inside of refrigrator compartment. leaving every thing filled with water in refrigrator.
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Sep 17, 2011 | Haier HRF10WNB Top Freezer Refrigerator
Refrigrator motor runs all the time
this unit may have a dirty condensor coil and the fan if goin may not be able to cool it .. ck the fan and clean the coil .. if this doesn't change the run times then it may be low on coolant . . things to note .. how are the tempts inside the freezer/ and the fresh food.. is ther ice build up in back of freezer . and will need a brand & model # to help you beter .. mm feed back pls ..
Jul 11, 2011 | Maytag Refrigerators
I have samsung refrigrator model RL729WCSW since yesterday the Fan inside refrigrator has Hitting noise and the sound will Stop When The Door Is Opened.would you explain me how to rectify the problem. the...
The defrost is not working and the fan is hitting ice buildup...
Check out these tips...they can help you figure out what is going wrong with your refrigerator
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 21, 2010 | Refrigerators
Ice maker water line freezes
Hi, it sounds like the water valve is leaking just enough to cause the water to freeze in the inlet tube. This is the most common fix.
If I can assist you further, please let me know.
Thanks
Vic
May 15, 2009 | Refrigerators
Ice despenser in side by side door, kenmore does not work
Pull the grill cover off near the floor and look to see if any of the wires have been cut. I found that the grill cover wore on the wires controlling the door functions. First the crushed ice function went, then the water dispenser went. I had splice the wires back together and am leaving the grill cover off. No problems since.
Jan 01, 2009 | KitchenAid Superba Architect KSCS25INSS...
I have a GE refrigrator, the ice maker is working, but no water is out from the door
the resevoir is at the back of the refrigerator side. you have to remove the drawers and then you can see it.
Dec 14, 2008 | GE GSL25JFPBS Side by Side Refrigerator
Whirlpool Gs5shaxnb02 Ice maker
is there water in the ice trays?if not try pushing the test button normally underneath the unit. possibly it will initiate a reset and start working. sometimes a limit is not activated when it should be.
Aug 07, 2008 | Whirlpool GS6NBEXR Side by Side...
Kenmore Side By Side Refrigrator ICe Make Not working
Is the icemaker producing ice and it's just not coming through the door? Or is the icemaker not even producing ice???
Mar 01, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigrator
Try checking your water valve in the back and see if its still good... thats what lets the water in... if its getting power to it
Sep 01, 2007 | Jenn-Air JS42CSFXDA Side by Side...
Refrigerators Logo
1,382 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
