Question about T-Mobile Sidekick II
My sidekick 2 has a white screen and just keeps vibrating everytime i try to charge it, can someone help me
  • Anonymous May 07, 2008
    yeah thats the same with me it keep vibrating
Mine did that too.... I just left it over night and then it took the charge the next day. Now I have a different problem... the phone says it is charging... the battery meter flashes 1, 2 and 3 bars like it is taking a charge but it's not... now it's dead and when I plug it in the red and green phone lights on the top and bottom of the scroll wheel flash really fast but no charging ??? HELP....
Posted on Sep 15, 2007
Turn on, vibrate, flash lights, turn off
Hi. Just try pressing the power button and reset button at the same time. Unit will vibrate when reset. You can use a paper clip or similiar to hit the reset button located behind the screen. After that, plug your device to charger for at least a couple of hours. Hope this helps.
May 22, 2009 | T-Mobile Sidekick II
Sidekick 3 screen is blank
If you tried reseating the lcd flex cable and it didn't help then you best option is to replace the lcd screen assembly.
It is really easy to do and they run about 25 dollars on ebay.
Here is the guide
Replace Sidekick 3 LCD
and here is a link to the screens
Sidekick 3 Screens
Feb 22, 2009 | T-Mobile Sidekick® 3 Cellular Phone
My sidekick 2 is turning on, but has a blank white screen. i tried turning it off, and charging it for a long period of time. i don't think i dropped it, but i have in the past. i dont know whats going on...
This is a problem most likely with the actual connection to the screen. that's why it is just showing all white, I have seen this before. Only way to have it fixed is to have it serviced. Go to your local provider's store and inquire there about service. If you need further assistance let me know.
Jan 22, 2009 | T-Mobile Sidekick II
this is a very simple solution if someone hasn't told you the answer yet.... just hold your sidekick right side up then flip it as if you were putting it on a table and then there will be a button with 2 arrows and then 1 with what looks as a dot hold in the button with the do until you see the screen start to light up
Jan 14, 2009 | T-Mobile Sidekick II
My sidekick 3 has sonething wrong with it.
So if the sidekick has suffered a drop or some other type of trauma, the cable for the lcd screen can come loose causing a white screen. Try the following guide to repair a white screen:
Fix a White LCD Screen on Sidekick 3
If it doesn't work, you can replace the Sidekick 3 screen assembly fairly easily. A new LCD assembly runs about 30 dollars from ebay. Here is a guide for that:
How to Replace a Sidekick 3 Screen
and here is a link to the screens on ebay:
Replacement Sidekick 3 LCD Screens for Sale
Hope that helps
Oct 13, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Sidekick 3 problems
You may be able to fix many of those things yourself. The trackball proabaly just needs to be clean. Does the LCD have a white screen when it is on? The Camera, well that may take some work.
For the white screen check out here:
If it is not white, a new lcd can be had for 45 dollars on ebay.
they are easy to replace.
replacement of the Sidekick 3 LCD flip screen.
To clean your track ball, follow these instructions:
1: Take a deep breath and blow on the trackball area, rotate and do it again. This may blow any particles block the sensors.
2: This requires a Q-tip and some alcohol. Turn off your sidekick, wet the end of the q-tip, and gently clean the trackball while rotating. Be careful not to get the alcohol on anything but the trackball. Let dry for a minute and try it out. If this doesn’t work then try again.
Apr 14, 2008 | T-Mobile Sidekick® 3 Cellular Phone
White screen
Your flex cable may have come loose. Check out the following link on how to check.
If not, a new one can be found on ebay for about 45 dollars.
Feb 21, 2008 | T-Mobile Sidekick® 3 Cellular Phone
TMobile Sidekick 2
yep, you can do a master reset.
Want to clear out info on your Sidekick info (ie: to sell yours)?
1) Remove your sim card
2) From the jump screen: Menu -> Settings -> System Info
3) Press Menu+Shift+X Select OK to clear the flash.
4) Press Menu+Shift+R Select OK to clear the login information.
5) Perform a hard reset now. This will reboot the device.
To perform a hard reset:
SK2 - Press the power button and reset button at the same time. Unit will vibrate when reset. You can use a paper clip or similiar to hit the reset button located behind the screen.
6) Call your carrier and ask them to detach your device IMEI from the username locked in. Once that is done, hard reset without your SIM card inserted.
You're done.
Jan 01, 2008 | T-Mobile Sidekick® 3 Cellular Phone
White Screen Reset problem!!!
hi my dad gave me his side kick id but for some reason the screen is white and some times hard to see can u help me!
Jul 09, 2007 | T-Mobile Sidekick II
T-Mobile Sidekick II Logo
105 people viewed this question
Top T-Mobile Computers & Internet Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
