Question about LG WM2077CW Laundry XL Front Load Stackable Washer
Washer doesn't spin
It seems there is a problem with the washer spinning. When I start the washer, water comes out but it doesn't spin anymore. The motor makes a noise like it wants to spin and then the sign "LE" comes out on the display. I took the back off and when I assist the motor in spinning, it will spin but then it stops again. I have a LG WM2077 front loader. Any suggestions? Thank you for your help!
  • 1 more comment
  • labellemaldo Sep 02, 2007
    I have no idea where the capacitor is, I have a repair man coming on Tuesday. Thank you for your help, I'd try to fix it myself if I knew what I was doing!! :)
  • Anonymous Nov 21, 2008
    Hi
    I have the same problem. The last load finished with water inside and it displayed LE on the screen. When I put a new load in it takes water in but doesn't spin. Help please
  • Anonymous Mar 21, 2014
    Noticed a smell like motor overheating. Though the wash was out of balance. Would not spin. Took wet clothes out, and drained water from from pump filter. Unplugged washer and let sit for about 30 in. Plugged back in and ran on spin. Washer ran, but rough, and still made a noise.
  • 641 Answers
Try to replace the capacitor and let me know with your results. Good luck!
Posted on Sep 02, 2007
SOURCE:
Kenmore washer model #796 front load washer - washer will not spin out - went to drain water from drain hose - no water will come out - so I unscrewed pump filter - water is pouring out of there - help
OK....I am here to RESCUE you...1st, DON"T do that anymore! You will get wet! LOL. Simple solution. You need a New Drain Pump replaced and installed. Once that is done. I do NOT want to hear about you going down there anymore and doing....That! LOL...
Your machine will be happy and spin.and drain all day Long!
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
Mar 05, 2014 | Washing Machines
Washer will not spin water out
There is a flap inside of the washer that comes up as the washer begins to spin...Just replace that valve and everything should be fine. As long as its spinning and washing you will not need to get a new one :)
Nov 19, 2012 | Washing Machines
GE Profile WPRE6150K2WT - washer pumping water but will not spin
Unplug the electric power cord. Disconnect the hoses and pull out the drain hose. Move the washer to a convenient location where you can work on the front and the back of it
No washer will spin when the lid is up. If the lid is down and it still wont spin, the first thing to check is the lid switch. If it's bad, the washer will think the lid is up all the time. You'll need to remove the front panel of the washer to see it.
Find the clips that hold the front of the washer on. They are on the front, about 3 inches from the sides. If you shine a light into the crack, you will be able to see these clips.
Insert a putty knife, pressing on the clips to release them. Then remove the front panel. Find the lid switch. Mine was on the right side. Make a note of the color of the wires that go to the lid switch.
Remove the back panel at the top of the washer where the timer and other controls are located. I needed a nut driver and a torx screwdriver.
Inside the back of the head unit, find the wires that come from the lid switch. Disconnect the white plug the wires go into.
Attach a volt meter to the end of the plug that comes from the lid switch. Set the meter to measure resistance or continuity. This means when the wires of the volt meter are touched together it beeps or shows a value of zero. Open and close the lid. If the readout on the meter doesn't change at all, then the lid switch is faulty. Replace it and the washer will now spin. If the lid switch is OK, go on to the next step.
Washers pump out all the water first, and then start spinning. If the water level switch is bad, the washer will think there is still water in the tubicon1.png and refuse to spin. From the front of the washer, locate the clear plastic hose on the left side. This goes to the water level switch.
Disconnect the hose by pulling upwards. Cleanicon1.png any junk out of the hose. On my washer, this clear plastic tube had some lint in it. By sucking on the tube at the front of the washer, I was able to remove it and the washer then worked perfectly. If this doesn't work for you, continue to the next step.
From the back of the washer, locate the water level switch on the right side. Disconnect the plug and attach your volt meter to the wires that come from the switch. Blow into the end of the hose you disconnected at the front of the washer and see if the meter changes. You should hear a clicking sound as you repeatedly blow into the tube. If the meter doesn't change at all, then the water level switch is bad. Replace it and you washer should spin correctly. If you are certain the lid and water level switches are OK, and the water level tube is not clogged. Then the problem is either the clutch or the motor
Nov 03, 2012 | GE Washing Machines
Washing machine does not empty
see the causes and use the common sense, God bless you.
If your washer won't drain, check these: It spins, but doesn't pump It doesn't spin or pump It pumps, but the water returns It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out. To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port. Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job. If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump. It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems: If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Sep 19, 2012 | Ariston Technologies Washing Machines
Washer hums but will not fill or start/ spin has water pressure and tub seems to move freely the model #on tag LTF2140ES0
If it doesn't fill it won't start any other cycle unless you move it ahead yourself. If it hums I am thinking it is trying to fill. Sounds like the valve is turning on to let water in but it is not getting through. My washer has a screen where the hoses go on and sometimes the screen becomes plugging with scale. If that is ok then the solenoid must be coming on but the valve is stuck. Does neither hot or cold settings work? Please rate my answer so I am rewarded points for it.
Jan 27, 2012 | Frigidaire Washing Machines
The water in my front-loaded kenmore-he washer is not draining and doesn't seem to spin very fast either.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 10, 2011 | Kenmore Front Load Washer
Our washer doesn't do a proper spin anymore. I kept getting a nF message on the digital read out. Despite several repetitions, I only got a humming from the machine with seemingly no spin. When the...
Hello, Thank You for using FixYa. I will be helping you today.NF means its not filling. If its the cold valve that's bad the unit will not spin.Check to make sure the water is turned on. If it is the humming you hear is most likely from the valve that is not opening to allow in water. depending on the series this could have two separate valve Assembly's
Thank You and please rate my answer if it was helpful..
Jun 19, 2011 | Maytag Neptune MAH5500B Front Load Washer
All the water does not spin out of the clothes & at times it doesn't even seem like it is spinning
heatman101
Jun 07, 2011 | Whirlpool LSR6334LQ Top Load Washer
Kenmore Oasis HE Washer
problem started when washer started itself up twice in the middle of the night....after that the washer seems to have problems figuring out what it wants to do...when running a wash it will start, run for 2 minutes then start scanning numbers...it does not land on a code...it will spin, stop, start...sears has replaced the mother board 3 times....and we will be phoning them again as it has not fixed the problem..one other time it did not spin properly and clothes were wet...we have a dedicated surge protector on it...we have had our electrical checked and no problems there...sears confirmed that as well..the techs have given up on it and don't know what to do with anymore...it is still under warranty and now costing sears more to service it then replace it....time for them to do the right thing and "take it back"...very disappointed in this washer...wish me luck when i call them again...they must be sick of hearing from me....lol
Apr 26, 2008 | Kenmore Oasis HE 27082 Top Load Washer
LG WM2077CW Laundry XL Front Load Stackable Washer Logo
268 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
jimorris77
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
