Where in North-Central London can I purchase a replacement gasket for a 1-2 cup vigano stovetop...
(More)
Where in North-Central London can I purchase a replacement gasket for a 1-2 cup vigano stovetop espresso maker?
have calc liquid for descaling coffee machine but cant find instructions how much should i use with...
(More)
have calc liquid for descaling coffee machine but cant find instructions how much should i use with 500ml water
We have a Saeco Odea Giro coffe machine, and it seems as if the sprouts are blocked, it grinds and...
(More)
We have a Saeco Odea Giro coffe machine, and it seems as if the sprouts are blocked, it grinds and pumps the coffee, but nothing comes out of the sprouts. it doesn't seems there is a pressure problem, but it sounds as if the machine is over working itself (pumping towards the inside)
hi ,I have been given a Nuova Simonelli Premier V,it has been imported from US.It came with a tank...
(More)
hi ,I have been given a Nuova Simonelli Premier V,it has been imported from US.It came with a tank for water supply (the machine was & is not connected to a main water supply)a metallic cylinder for water softener,a tall blue softener and a pump.The machine seems to be running OK but I can see that in the gauge pressure only one of the two seems to work.The metallic cylinder is empty and I don't know what I have to put into it,recently a colleague forgot to start the pump,made some coffee and run out of water,I was looking for a way to feel the internal tank with no luck.Is there anyone who can help me? Thank you very much
