Lexmark P4350 All-In-One InkJet Printer Logo
Posted on Sep 01, 2007
Lexmark 4350 and Vista
Have been using Lexmark 4350 for a while with Windows XP. All well. Now have Windows vista. Tried to install with installation disc and it would not work at all. Downloaded Vista driver from Lexmark and now the scanner works but the printer will not. I just get message "Problem communicating with the printer" . Any ideas please?
  • 7 more comments
  • Joshkroy Sep 02, 2007
    Thanks for offering suggestion but yes, I did already download the driver from Lexmark. However, the driver does not install correctly. I have done this 3 separate times so far, each time ensuring previous drivers were erased first and turning off Norton protection during installation. I end up every time with a message saying the driver has not installed properly. The scanner part of the Lexmark 4350 works fine but it will not print anything at all. Although there clearly IS communication between computer and printer (otherwise the scanner could not be activated by the computer) when it comes to printing it keeps saying "problem communicating with the printer".
  • Anonymous Jun 11, 2008
    Lexmark printer 4350 works fine with Windows xp, now can't install to windows vista
  • Anonymous Jun 24, 2008
    I HAVE THE SAME PROBLEM WITH LEXMARK 4350 SCANNING BUT NOT PRINTING (VISTA)
  • Anonymous Jul 02, 2008
    printer wont dowload at all,tried
  • Anonymous Oct 26, 2008
    Not only cannot install new version, cannot uninstall old drivers for printer. Vista...
  • sarak3498 Oct 27, 2008
    I have recently acquired a Toshiba laptop with Vista ( not by choice) replacement through insurance. I have tried to install Lexmark all in oneP4350 printer cannot print anything at all!! I have been onto advised site with no luck. Please help.
  • Anonymous Oct 30, 2008
    KEEPS SAYING DETACH POWER AND USB THEN RESTART COMPUTER STILL NOTHING
  • Anonymous Nov 03, 2008
    Same problem Will scan and copy but will not print. Another winblows POS OS. At least XP and W2K worked.
  • olegtov Jan 18, 2009
    I have tried installing Lexmark p4350 printer on 2 different computers, one with XP, one with Vista. I have even reinstalled windows multiple times and tried again, no avail. I think it might be an issue on the side of Lexmark. Driver installed incorrectly
redsocks
Level 1:
  • Contributor 1 Answer
  • Posted on Sep 02, 2007
redsocks
Contributor
Level 1:
Answers
Questions
0
Helped
902
Points
Hi I found that you can download the drivers for vista here http://downloads.lexmark.com/cgi-perl/do... Good luck Redsocks
Anonymous
Level 1:
  • Posted on Nov 13, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
902
Points
I had a similar issue when I tried to connect to my printer via P2P. The older drivers were installed and the printer would not function correctly. After I found the correct drivers I attempted to install and always got the same error, "an older version has been found blah blah."
My solution is I did a system restore before I connected to the printer and installed the Vista drivers.
Havng a problem installing lexmark 4350 printer on windows vista ? 3.5 hrs and still nothing will print ?
Is the Lexmark software already installed in your Vista computer? What did you use to install the sofware, the installation cd or the downloaded file? Did you get any particular errors when installing?
Are you getting any error when printing?
40helpful
2answers
INSTALLATION OF LEXMARK X5250 PRINTER ON WINDOWS 7
Hi, Lexmark printer drivers can be found on this site: Driver Update Software for XP Vista 7 8. Have a nice day
Thomas
I have a lexmark 4300,i ran the cd that came with it,but it just would not complete the installation of the software? MY LEXMARK 4350 WAS WORKING BEFORE WITH VISTA.. AND I HAD TO REBOOT MY WHOLE COMPUTER...
If you are still using Vista, the 4350 CD probably does not contain the Vista driver. You can uninstall the previous driver and install the latest Vista driver from:
http://downloads.lexmark.com:80/perl/downloads/downloads.cgi?ccs=229:1:0:479:0:0
Choose the appropriate driver, 32bit or 64bit.
Lexmark 4350 will not run with windows vista
You will have to download and install the VISTA driver for this model printer. Link provided below:
http://search.lexmark.com/printer/US/en/22D0000
Lexmark z25 drivers for windows vista
hi cathy it seems lexmark dont have vista drivers for this yet only drivers for the following Drivers and Downloads
riz.
The printer hardware does not support vista, hence there no drivers for vista by lexmark .
2answers
hello loloonlyone
thank's to seajade post . theres a link for which was rated as working for vista scroll to seajades post it may help you also .
hope this help's .
riz.
2answers
well..try this link first get new drivers..a hint..remove the other printer first, instead over lapping it
7helpful
4answers
I have the same problem. The Lexmark printer z 25 do not work on windows Vista. Please give a solution.
2helpful
2answers
Unfortunately, the Z25 isn't supported by Vista.
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
