I do not have knolage of how to take off the cover but I have replaced start cords on other saws. There is a hole in the pully you put the rope through and then tie a knot it it so it won't pull out.Usually there is a half circle in the edge of the pulley you place the rope in so you can wind up the spring but not take up the rope. You will need to count the turns the pulley makes when the rope is pulled out then add one or two more turns so the rope is pulled in snug. Then you take the rope out of the notch and let it coil up nomally.
SOURCE: HOW TO INSTALL A NEW CHAIN ON POULAN 16'' BLACKHAWK CHAINSAW
hi likniz
unlock the lock nuts,take off the chain cover,change the chain,adjust the screw tightening chain,back the cover and the lock nuts.
best wishes savumihai71
SOURCE: I have inheirited a Poulan counter vibe 3400 it
Go to m-and-d.com then parts diagram then illustrated parts online then parts look up then select oem poulan then poulan then saw then look at list of models you will find 3400. Have worked on one or two of the 3400 and they seem to be a fairly good saw for home use.
SOURCE: Pole Saw RPS96 - - Saw 108526-01 - - The outer
Your pole saw is at the bolttom of the page here:
http://www.desaparts.com/remington-chainsaw.html
The parts list that appears is a chainsaw. Please phone them @ 1-800-475-5660, ask for assistance and explain this little glitch. Thanks HTH
Lou
