I am using Nero 7 to burn DVD's. I can set up a file to be burned but once it starts to go to the burning process it ejects the disc saying insert blank DVD, while I do have a blank DVD in the drive.
yeah I had the same problem. The DVD Writer will not write and read DVDs, but functions great with CDs, so I forgot it as a DVD write and considering it as CD writer and using it. If possible if you want to make it work by risking then you can try changing the DVD regions and firmware. But, you will be at your own risk.
Comment by Sakibanda, posted on Sep 05, 2007
Forget it as a DVD Writer and feel it as a CD writer, becoz i did the same thing. I tried a lot to fix this but failed. But, you still does not agree then there are two ways to messing up with this first is changing your region to suitable only but only 5 times and then firmware upgrading or replacing.
Rating Locked! (?) Abel003 has rated this solution as FixYa!
Thank You!
Was the solution helpful?
Show your appreciation by commenting on DVD burning problem:
I have had the same problem and I have three burners set up on the same computer all of them did the same thing, Like sandrew said try a different dvd-r or dvd+r I noticed when I put in the right one it worked fine, I think nero Has a test to see what your speed is and to check out what type it is, How old is the dvd burner Let me Know there are some other type of tests we can do Hope that Helps you out. Other than that Maybe its just gone bad
Was this solution helpful? Show your Appreciation by rating it:
if you have tried different dvd-r and dvd-rw discs, unfortunately it's a sign that your writer is failing to read the discs correctly, this normally happens when the writer is about to give up, although it may still write and read cd's but not dvd's
Rating Locked! (?) Abel003 has rated this solution as Not Rated
Thank You!
