Question about Motorola Mobility RAZR V3c Cellular Phone
Help We are were at a rainy baseball game last night where my phone got wet. I have just had it 3 months. The screen actually turns on, but the numbers will not work and it even rings but I cannot answer it. What can I do?
  • 3 Answers
Open the back of the case. Take out the battery and see if the little circle is white still. If not the warranty will be over. You can try and explain that to a rep what happened and they may help you.
Posted on Sep 04, 2007
SOURCE:
No data loading...
I'm having the EXACT same issue. I did a google search for any advice and found your question. Is it possible that Ambient is no longer supporting the scorecaster? I just bought mine last month.
Apr 02, 2014 | Ambient Baseball Scorecast Stat Tracker
HTC Vivid won't turn on
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Aug 04, 2012 | HTC Vivid
Our Hitachi tv turns on okay but the picture on comes in for 2-3 seconds and then the screen goes black. Last night the tv work just fine but this problem started today as I turned the tv on to watch...
I don't know what model you have,but... I have a 50v715 and it was doing the same thing and it turned out to be the lamp. So if you have not replaced the lamp in a while then it could just be it time. Hope this is helpful.
Oct 03, 2009 | Hitachi Televison & Video
White Screen
the screen is skrew you should get a new onne because its expensive to replace it
May 19, 2009 | LG CHOCOLATE VX8500 Cellular Phone
Razr V3 water damage
Sounds dire. If you look inside the back of the phone, there should be a small spot that turns from white to pink when the phone gets wet. If that spot is bright pink, most repairers won't even bother trying to fix it. Best off buying another phone!
Apr 07, 2009 | Motorola Mobility RAZR V3
1997 Jetta 4 Doors Won't Start on rainy, wet and cold days
Damp is getting into your electrics. Spray all wires and disributor with WD40 after wet days or nights before trying to start it. That should cure it
Mar 30, 2009 | 1997 Volkswagen Jetta
LCD Erroe
Some water got in to the screen and maybe some of the boards in the computer. It eventualy caused damage. The fix is to try the screen, connector and ribbon assemblies, and the display daughter board if there is a daughter board in your model. It is also possible that the mother board has a fault.
This type of fault can end up being expensive to service.
Jerry G.
Jan 31, 2009 | ASUS Eee 4G Notebook
Game wont load
ts a problem with the latest download update. sorry to say but its a job for sony as long as its still under warranty. just phone them up explain the probs your having and they will send you a new (normally reconditioned) unit out. sony's replacement service is very good.
Feb 10, 2008 | Sony Playstation 3 (PS3) Console
Motorola Mobility RAZR V3c Cellular Phone Logo
56 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
