Question about Acer Aspire 3610 Notebook
Acer aspire 3610 graphic or battery problem?
I have an aspire 3610 its around 18 months old, last night the screen went blank, although thats what i thought, if you look closely everything is still there, its as though the lights have gone out. Anyway, i powered down and rebooted, the screen came back on, but went dark again within 20 seconds. If i use the laptop without the ac adapter in it will work ok? as soon as i plug in the ac it goes dark again? the battery only lasts about 30 mins total, on start up the screen has a bit of an orange tint, which dissapears once loaded. THe laptop goes dark straight away if i remove the battery and only power up with the ac cord. Im desparate for a solution or advice, as all my worko is on the laptop and i cant afford a new one. any suggestions would be received with thanks, Tracy
  • ottyonion Sep 01, 2007
    Thank you for your comments, unfortuantley i am in the uk, so the lcd on ebay would be too costly to ship here from the usa.
    Also if the backlight has gone, why does the laptop power up and work fine when its not plugged into the ac adapter? this is one thing i dont understand
    THANK YOU, I WILL TRY THAT AND POST AND LET YOU KNOW, THANK YOU FOR YOUR HELP
    Sergeant:
  • 279 Answers
It sounds like your backlight is damaged. On some units this can be replaced on its own. On others, it requires the entire LCD to be replaced. I'll see if I can find out which this is, in your case, and find you a part number.
Posted on Sep 01, 2007
  • John Goodman Sep 01, 2007
    Apparently, you can't just replace the backlight.
    And finding a new LCD proved very difficult. Finally, I found one on eBay. I could not find any online stores that carried them.
    http://cgi.ebay.com/NEW-ACER-ASPIRE-3610...
    You could try calling a local repair shop. I'm sure they would know how to order them, and likely be willing to sell you one. The eBay auction above has detailed instructions on replacing this LCD. I suggest saving those even if you don't buy the LCD from them.
    You know, I overlooked that fact. There's another possibility, and a much easier one.
    Your power inverter may be going out. So when you plug it in, it's not providing reliable voltage to the backlight. The backlight runs on a different voltage level than the rest of the computer, so it could be affected while the rest of the computer isn't.
    Can you get ahold of another power inverter (the brick part of the power cord) for this unit to test it with? I'd suggest taking it into a repair shop and seeing if they have one you can try on it. And if that fixes it, buy it from them (even if they do charge a few pounds more, they did you a favor after all).
SOURCE:
8380hi, i have an acer aspire one approx. 18 months old. it now wont power up the green on button lights up when turend on but the screen remains blank. any ideas
Remove the battery, and unplug the A/C adapter and hold down the power button, for 40 seconds.Soon your laptop will reset,and run well.Now you will install all the accessories and start.
Hope this helps you.
Feb 19, 2011 | Acer Aspire One PC Notebook
After replacing my broken screen on a Acer Aspire 3610 15.4 I have no display ,only back light on the screen, It will come up on a cpu to the opening screen then blank . I have the origional cables to the...
If you get a normal ACER screen boot then it goes dim, then your inverter is probably bad.
Just swap the inverter and you should be back in business.
Mar 02, 2009 | Acer Aspire 3610 Notebook
Screen Blank
there is a connection problem with the screen or a graphics chip fault, being as it's only 6 months old, do not void the warranty by trying to remove anything, return to your original selling retailer
Aug 30, 2008 | Acer Aspire 5520-5908 Notebook
Aspire 3610 Bios Password???
The motherboard manufacturers are Phenoix, as it says on bootup. I'm not sure if you can recover the BIOS password by simple keystrokes/buffer overflows anymore, although I heard that some motherboards still have the password running in volatile memory, meaning that if you remove the battery it could reset the password (along with any custom settings and the clock).
Jul 24, 2008 | Acer Aspire 3610 Notebook
Acer Aspire 5580 poor battery
Its time for a new battery. After a period of time of using a battery, the amount of charge it can hold depletes. Even if you always have it plugged in. Usually, batteries only last 18-24 months which is sad, seeing how much they cost. I'm a computer tech and see this problem everyday first hand. The best thing you can do is buy a battery from eBay and save yourself a bunch of money. Local retail stores charge up to 3 times as much for a battery. Good luck and I hope this helps..... :>)
May 31, 2008 | Acer Aspire 5500 5570-2609 Laptop
Battery
I can't forsee a problem but I'd backup my system and buy a backup battery if it were my system.
There are so many computer parts/battery stores online these days but I can't recommend any particular one. Shop around and do some price comparisons. I've had luck buying batteries on ebay, but use caution there or you might end up buying a battery that's deader than yours.
Cheers,
Rick
Mar 14, 2008 | Acer Aspire 3610 Notebook
Acer aspire 5630 with vista home premium
That would be my guess. Since it is still under warranty, take it back and let them mess with it.
Jan 06, 2008 | Acer Aspire 5630 Notebook
Acer Aspire 3610 Notebook Logo
189 people viewed this question
Ekse
Alun Cox
