Question about Sony PlayStation Portable (PSP) Console
Password prob I brought A PSP used and i Dont have the parental control Password what should i do?
  • luckypito Sep 01, 2007
    This is all right.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 78 Answers
Go to settings > system settings > restore default settings although this means there will be no parental control you will need to set the clock time and wallpaper again
Posted on Sep 02, 2007
SOURCE:
I cant unlock parental control we forgot password
In your console enter to the parental control menu and try to change it, when asking for password then:
1. Click "I forgot" twice.
2.
Go to http://wii.marcansoft.com/parental.psp
3.
Copy the inquiry code where it says "Confirmation Number:".
4.
Select your "Current Date in your timezone:"
5.
Push the "Get Reset Code" button and get your master code.
6.
Try to change again the parental control and use the code provided, the code should work as I tested it many times.
NOTE1: the code generated in this page work as well for Wii and DSi consoles.
NOTE2: If it doesn't work the first time, try going to http://www.timeanddate.com/worldclock/ . Change the time/date on your DSI to match that of Tokyo, London, some other location etc and then try again.
Jul 09, 2010 | Nintendo DSi Black Console
Kids playing with system put lock code on it and now we cant get off dont know what it is..parental control
Try 0000 and then 9999. These are the default passwords. If those don't work:
Turn on the PSP.
In the main menu, under "Settings" (Toolbox Icon), go to System Settings. Press X.
Go to "Restore Default Settings". Press X
The password should reset to 0000 or 9999.
Aug 09, 2009 | Sony PlayStation Portable (PSP) Slim...
I forgot my parental control password
Go to settings, select System settings and scroll down to RESTORE SYSTEM DEFAULTS. use that feature, after that the password should then be 0000 or 9999.
Apr 20, 2009 | Sony PSP (Piano Black)
I bought a psp and parental controls are on and i dont have the password from the previous owner anyone know the reset code?
To Reset the password go to
System > System Settings > Restore Default Settings
then the password should be removed
Apr 20, 2009 | Video Game Consoles & Games
I dont have the password
the password when you get the PSP is usually 0000 or 1111
remember to rate this awnser
gabriel
Jun 03, 2008 | Sony PlayStation Portable (PSP) Console
Parental lock
Child Lock
Combos
--Should have original remote. Press and hold the power button for 6 to 10 seconds
Combo Model T25208, V-Chip Forgotten Password
If you forget your password, simultaneously press VOLUME down on the TV/VCR front panel and the 0 number button on the remote for a few seconds. This resets the password and you can enter a new one.
Combo Model 13TVR62, V-Chip Forgotten Password
If you forget your password, press STOP/EJECT on the TV/VCR front panel and MENU on the remote simultaneously. This resets the password, but not the limits you’ve set.
Televisions with Parental Lock Feature
If you forgot your password for this feature, press the following buttons on the remote, one at a time. (Note: You must be in the password entry screen) Press, Mute, Display,Clear and Reset, this unlocks parental controls and you can now re-enter a new password.
OR TRY THIS..
Press and hold Menu on the TV AND volume down on the remote for 3 seconds. Nothing will appear on the screen, and the Parental Controls will unlock, and you can re-enter a new password with the LOCK PARENTAL CONTROLS
CTC169AU
Channels that have been locked can be viewed only when the PARENTAL CTRL function is set to OFF. This can only be done with the remote control-it can not be changed with the buttons on the front of the TV.
Therefore, after you turn on PARENTAL CTRL, you simply hide the remote control so that your children can not watch the locked channels. The locked-out channels will remain unviewable even if the TV is unplugged or the channels are autoprogrammed again. The only way to view locked channels is to use the supplied remote control to set the PARENTAL CTRL function to OFF.
The PARENTAL CTRL and the CHAN CTRL functions work hand-in-hand. The instructions below will first tell you how to turn parental control on or off with the PARENTAL CTRL function and then how to lock desired channels with the CHAN CTRL function.
1. Repeatedly press MENU to select SETUP MENU, and then press + or - to display setup functions. Repeatedly press MENU to select the PARENTAL CTRL function. . When this function is set to ON, PARENTAL CTRL is activated and any channels you locked with the CHAN CTRL function will not be viewable. . When this function is set to OFF, PARENTAL CTRL is deactivated and all channels are viewable.
2. To lock channels, press the MENU button to select the CHAN CTRL function. Select a channel you want to lock by pressing CHANNEL up or down. Then press +. The CHAN CTRL setting will change from NORMAL to LOCKED when that channel is locked. To return the channel to NORMAL, press the - button. Repeat step 2 for each channel you want to lock. If the PARENTAL CTRL function is set to ON while you are locking out channels, each channel will go blank as you lock it. When the PARENTAL CTRL function is set to ON and a channel which has been locked out is tuned, the TV will display the words PARENTAL CONTROL to let your kids know you have locked it.
CTC185's
If the front panel function buttons don't work, (menu, ch up/dn etc.) but the functions work normal with the remote, enter the "Channel" menu with the remote and turn "Parental Control" off.
CTC203's
In the event you have forgotten your password, perform the following procedure:
Press and hold for 3 seconds the TV button on the remote while pressing the menu button on the TV.
This procedure will turn off the parental lock and erase the previous password .
Another Possibility To Try For Various Models: If TV's in the Parental mode and askes for a password that's forgotten, Press menu on the TV, select Parental Lock #4 on menu, then with the remote press Mute, Display, Clear, and Reset buttons in sequence.
TX808 Chassis
If Parental Controls have been set and you don't know the password, do this:
Press and hold the volume down and the channel up buttons at the same time for 5 seconds.
Now you can reset the password to 0000, and using that password you can now access the V-Chip menus.
TV's (Made by Daewoo or possibly Apex, ie. GE model 24GP653)
The factory default pass code of 6688 is also the override code, in case the owner forgets their pass code. If that doesn't work, another place in the owners manual says to push Function and Mute on the remote at the same time. Function is the top right button.
Mar 26, 2008 | RCA TruFlat 27F520T 27" TV
V chip password
Parental Guide On (Activate V-Chip)
Selecting this option lets you activate and deactivate parental control settings.
1. Press MENU on the remote control (the Main menu appears).
2. Press the button until the Parental Control icon is highlighted.
3. Press the button until the bottom PASSWORD is highlighted.
4. Enter your password using the numbers buttons on the remote (the PARENTAL GUIDE menu appears).
5. Press the button to highlight PARENTAL GUIDE OFF, then press the button to turn it on. It must be
on for rating limits to take effect.
If you do not activate V-Chip, none of the settings for V-Chip will take effect.
If you forget your password, you can reset it. Enter 5898 as the password and then change it to a new one.
Child Lock
Selecting this option lets you lock (disable) or unlock (enable) the TV’s front panel. The remote still tunes to
any channel. When using this as a Parental Control method, remove access to any remote that is capable of
operating the television.
5. Press the button to highlight CHILD LOCK, then press the button to turn it on.
Change Password
Selecting this option lets you simply create a new password at any time. Once you enter a new password
from CHANGE PASSWORD in the PARENTAL CONTROL menu, it is the password you use until you change it
again.
5. Press the button to highlight CHANGE PASSWORD, then press the button to select it.
6. Press the button to highlight NEW PASSWORD, and use the number buttons on the remote to enter
the new password. Enter it again in the confirm field to confirm the new password.
Mar 20, 2008 | RCA 20F510TD 20 in. TV/DVD Combo
Playstation 2
when you are asked to enter the password press 'select' and then insert '7444' and you will be asked to enter the new password just enter any 4 digit number. If you want to clear the password completely then, during the film press 'select', 'setup', 'parental control' (tab) and there turn it of.
Jan 18, 2008 | Sony PlayStation 2 (PS2) Console
Sony PlayStation Portable (PSP) Console Logo
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
