SOURCE: jenn-air jes9800AAB keeps buzzzing, front function panel flashes on and off
Your control panel is getting ready to quit. Mine did the same thing, I ignored it and now nothing on the touch panel works. About $150.00 for the part.
SOURCE: I have a Jenn Air SVD48600W dual fuel stove.
it is indeed your control panel
it shopuld be covered under the 5 year warrenty
SOURCE: Jenn-Air JJW8530 LCD panel does not light up
BrianGem posted a great solution back in May of '08, I just completed that fix on my own Jenn air, took me about 30 minutes once I got the correct capacitor.
The display board apparently has a weak spot in the design, most likely heat related, (probably low priced components from offshore sources)
Fix: Replace heat damaged capacitor labeled C3 on display board, Hard part will be obtaining the 35Volt 68uF capacitor, I'm lucky enough to have a Brother in the electronics design field who found me a couple of high reliability caps designed for hot applications, He does not recommend changing sizes without design review for fear of overloading another component, however several other posts have indicated that a 35V 100mF cap has worked fine for them.
TURN OFF POWER TO OVEN PRIOR TO STARTING ANY REPAIRS.
My control panel was attached to the oven with 4 screws accessed from above the top oven door, the panel slid up about 1/2 " and lifted off, Unplug the ribbon cables and the panel can be removed to a convenient work surface. The display board itself is mounted with 4 screws and connected with a wide flat ribbon cable, the suspect capacitor is surface mounted to the reverse side of the board, two plastic clips need to be released (gently) and the ribbon cable unplugged. Capacitor is likely discolored or leaking, Using as small a soldering iron as you can find De-solder it and replace with new, match polarity marks and don’t use any more solder than needed.
If you run into trouble drop me an e-mail to [email protected] and I’ll try to help.
Good luck.
Thanks for this site..
Link to Photo sequence of capacitor replacement (Captions still will not link):
http://picasaweb.google.com/dltatsjc/Photos?authkey=Gv1sRgCJPKv9CRgsXxNA
SOURCE: Jenn-air electric double control does not work - clock is on
Disconnect the Power Supply for few minutes, say 30 minutes and then Turn the Oven ON.
Do you see any Error Message?
How old the Unit is?
Do you have any Experience to Fix this?
Do you have all the tools?
Let me know, so that we could proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
SOURCE: JGS8860BDP Jenn Air 300" Range
I understand that a few buttons (Top 2 rows) are not working on the kitchen range.
An issue like this is most often caused by a problem in the control panel's keypad.
Resolving this requires the control panel to be replaced.
