Question about EliteGroup GeForce 6100SM-M Motherboard
Front panel hookups
Hello i have this geforce 6100SM-M board and im having a problem hooking up the front panel stuff to it .. there is a reset power switch power switch .. hdd led and power switch + & - and on other is vcc1,data-1and data+1 and ground 1 and same but vcc2 etc i dont know how to hook these up there is 2 USB 1 and 2
  • r_cd5916 Mar 24, 2009
    I need to visually see how to rewire the front panel connections i have the manual but it does not show excatly how to wire it if you have a diagram of what this is suppose to look like please let me know i have this motherboard
    put in a new hard drive and reformated get into windows setup then the computer locks-up and i can not shut computer down unless i shut it off in the back of the cpu
    President:
  • 2,961 Answers
Go to the link below and you can download the manual for instructions on front panel connections http://www.ecs.com.tw/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=685&DetailName=Manual&DetailDesc=GeForce6100SM-M(V1.0)&CategoryID=1&MenuID=39&LanID=9
Posted on Sep 01, 2007
SOURCE:
Motherboard not turn off, when shuting down and turning on without pressing front power switch.
make sure that the front pannel switch is not stuck or having some prob
i had the same prob i changed the switch its normal now
Jan 25, 2010 | EliteGroup GeForce 6100SM-M Motherboard
Hookup of front panel lights and reset switch
Look on your motherboard. the pins have very small writing so use a strong lite. Your motherboard manufactures web site should have the manual. The manual will give pin locations and how to install.
Jun 08, 2009 | Matsonic MS9337c Motherboard
Where to hookup front panel (PIII-3754LMR - AMPTRON)
Front Panel Connector The front panel header is where the connectors of hard disk drive activity lights, case speaker, reset button, power on/off button, computer power on light, and key lock, are connected to make them function smoothly. In the past days, users always have difficulty connecting the front panel due to a lack of standard location on the motherboard. Today, AOpen integrated all these disorder but essential front panel connectors into one 20-pin connector for easy usage. Connecting the front panel would no longer be the headache of installing motherboard anymore. Below is a view of this user-friendly front panel connector of AOpen motherboard.
please rate this post.
or donate on [email protected]
Feb 08, 2009 | Intel Motherboard
Projection set- 57h82 - need plug location for signal board hookup from control panel on front,and av jack panel,and hookup for if module standing up
FRONT PANEL HOOK UP IS EITHER TO IR PICKUP BOARD ON THE TOP OF THE BLOCK BY THE CRT LENSES OR ON THE FRONT OF THE SIGNAL BOARD.
Jan 22, 2009 | Toshiba 57H81 57" Rear Projection...
No activity whatsoever
Hi there on the board there is a speakers socket( 2 or 3 pins) near the power connections for front switching,try booting with no ram after you get a speaker connected or piezo buzzer,change out ram if you can
Jan 15, 2009 | EliteGroup GeForce 6100SM-M Motherboard
Video
Here is the support page for your motherboard:
GeForce 6100SM-M
Oct 27, 2008 | EliteGroup GeForce 6100SM-M Motherboard
COMPUTER LOCKUP PLAYING GAMES.
could be the CPU is overheating, you may want to check and make sure all fans are working properly, as well as making sure you have a decent amount of thermal paste on your heatsink, i recommend antec silver.
Aug 29, 2008 | EliteGroup GeForce 6100SM-M Motherboard
Bios update
general instructions
http://www.wikihow.com/Update-Your-Computer's-BIOS
1. find the update
2. find the update software
3. find a dos boot diskette or cd from www.bootdisk.com
4. continue with the wikihow
Apr 03, 2008 | EliteGroup GeForce 6100SM-M Motherboard
EliteGroup GeForce 6100Sm-M Problem
4 things can cause this MB to do as you mention.
Bad CPU or the MB is not sensing the CPU fan and is protecting CPU from overheating.
Bad or inconpatible memory, If multiple sticks use only 1 at a time, This MB is known for having problems with both slots filled most of the time bios resaves can fix this but just set up with 1 first.
Reset the bios, Make sure the reset jumper is set back correctly.
Make sure it post without any extra harware hooked up first then add them.
The beeps are a old style of signaling the problem, You can find charts online that will tell you what the beeps mean long and short.
Nov 27, 2007 | EliteGroup GeForce 6100SM-M Motherboard
EliteGroup GeForce 6100SM-M Motherboard Logo
478 people viewed this question
Top EliteGroup Computers & Internet Experts
Alun Cox
Thomas F. Schneider
Ekse
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
