Question about RCA RCR430S Remote Control
Rcr430s programming I cannot find how to reprogram my remote. The only thing I can find involves a code search button which do not have.
  • 9 more comments
  • tyronecaces Nov 08, 2007
    same thing i cannot find the manual and im trying to reprogram and for some reason i cannot find that manual on the interner
  • cyberhansa Dec 16, 2007
    I am trying to reprogram the RCA RCR430S remote and as soon as I follow the intstructions, the LED flashes 4 times telling me that it has already searched all of the codes. I just have a Sony tv I am trying to program for, I cant figure out what I'm doing wrong...
  • brian59 Feb 23, 2008
    need info on how to program
    need help programming rca remote rcr430s
  • LostRemote Mar 15, 2008
    I have a Sylvania TV/DVD 15" LCD. I can't get either RCR812 or RCR430S remote to program.
  • carolsipf Mar 21, 2008
    how to program
  • Anonymous Apr 10, 2008
    hi, i donĀ“t know how to reprogram my remote, i been lost my manual
  • Dave6552 May 26, 2008
    www.fixya.com/support/t191589-rcr430s_programming
  • Anonymous Nov 17, 2008
    i need the code 4 the remote
  • Anonymous Feb 01, 2009
    I have misplaced my instructions on how to program my TV.
  • Anonymous May 16, 2009
    I lost the instructions manual but I still have the code list. I can't find the manual on the rca website.
I had the same problem and was able to find the manual online. Here is the link, I hope it helps!
http://157.254.235.130/public/RCR430S_REVA.pdf
Posted on Nov 18, 2007
OMG - you are a lifesaver, I was about to go nuts:)
Posted on Dec 29, 2007
SOURCE:
Rcr430s
Plug the part number into Google, then search for Manual, print it out and work it.
Jan 05, 2012 | RCA Universal Remote Control
Lost book to help program my rca universal remote for a tv need codes for sharp tv and what buttons to push to enter codes
We would need the model of the RCA 4 in 1 to direct you to a PDF copy of the manual. You can go to this link and enter the make and model to locate the manual.
http://tv.manualsonline.com/manuals/mfg/rca/rcr430s.html
Jul 01, 2010 | RCA 4-in-1 Universal Remote Control
I have and RCA RCR311ST Universal Rmote Contro which I can not seem to find the Cole Selector button to program my Orion TV any ideas?
I can help you reprogram your RCA RCR311ST for all your Orion TV. The folks at RCA did away with a code search button for this model and you must press a combination of buttons to setup programming more.
Please review my Fixya Tip posts for:
  1. Searching for the proper codes, or
  2. Entering the codes you have looked up for your Orion TV on this remote's device code list.
I hope that helps.
Jan 20, 2010 | RCA RCR311S Remote Control
I have a Haier 13 inch television set TN131AUV and need code for it - and the rca universal remote I am trying to use in and RCR430S
You can go in to Google and put in manual for and then the model of your remote and it should give you the options to download the manual along with the codes.
Dec 29, 2009 | RCA RCR430S Remote Control
Need codes for rcr430s
go to tv.manualsonline.com/manuals/mfg/rca/rcr to get help
Aug 26, 2009 | RCA RCR430S Remote Control
Remote control programming
this rca should work on your rca tv , but here is the manualand how to clear a code for a device and reprogram it to the new device
scroll down to the second pdf file page ( thats where the instructions are for the reprogramming of selected device on remote ) http://www.remotes.com/remotes/documents/RCA/257003.pdf
Jan 01, 2009 | RCA 257003 Remote Control
Reprograming
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
Jun 20, 2008 | Philips Televison & Video
RCA CRK76TE1 Programming codes needed for a Daewoo T.V.
the following websites has the codes for that remote
all you have to do is look for the right model
http://remotes.com/store/codes_original.html
May 26, 2008 | RCA RCR430S Remote Control
Reprogramming my remote
i have a oneforall remote control i need to program my rca vhs can you help me find code
May 20, 2008 | Televison & Video
Universal remote
Codes for Samsung (one of them should work on your RCA remote)
006,011,014,015,019,027,036,037,077
Programming Your Universal Remote.
The remote may already be set up to operate your brand of TV, VCR, or Cable Box. It is pre-programmed with following codes:
  • TV-000
  • VCR-000
  • Cable Box-000
  • AUX is programmed with VCR code 037
For brands that require programming, there are two ways to program: Using Code Lists or Code Search. Use Code Search if the code lists are not available or if the codes from the lists do not operate a device.
Programming a Device using Code Search:
  1. Manually turn ON your device (TV, VCR, Cable Box)
  2. Press and "HOLD" CODE SEARCH
  3. Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
  4. Release CODE SEARCH.
  5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
  6. Once the device turns off, press and release ENTER.
  7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Programming a device using the Code Lists:
  1. Find codes for each device and brand below.
  2. Press and "HOLD" CODE SEARCH.
  3. Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step.
  4. Enter the three digit code from the TV, VCR or Cable Box code lists.
  5. Release CODE SEARCH.
  6. With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists.
Apr 07, 2008 | RCA Universal Remote 3 Device Remote...
RCA RCR430S Remote Control Logo
4,870 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
