My laptop works and turns on and i play with it fine but the led light shows that its charging while its plugged in but then goes black and then comes back on to charging again. would this be the battery or the adapter?
Hello !! first of all check for bad connection on the led strips if all connection ok , test the single led one by one , at the end Do not Hesitate replace the leds strips . Because problem could happen after heating .
Sometimes if charged too long or your not around when the light does go off, after awhile the battery looses its charge. when that happens the charger will start to charge again and it will seem that it isn't working right or charging. in your instruction booklet it should tell you how long it should take to charge. some say 45 min some say hours. set a timer once you find the time recommended for your device, once it goes off unplug if light is off. good luck
This is OK the Red LED Has just gone out... simply just keep an eye on time if you think that it might die soon plug it in... there is not much that you can do to fix it.
Try to connect the AC adaptor of your laptop and plug it to the wall outlet and let it charge for 3 hours or more. When you plug it on the wall socket, it won't show the laptop's led blinking since it was totally drained. But after 3 minutes or more, it will start to show the blinking led to indicate charging. When blinking stops led light disappears, it is fully charged and ready to use.
Remember: Do not use your laptop while it is plugged in to save your battery life. When at home, remove the battery while it is fully charged and plug the AC adaptor directly to the wall outlet. It will still work without the battery as long as it is plugged directly to the wall socket.
