Home | Escort | Passport 8500 Radar Detector | False Laser warning whe...
Escort Passport 8500 Radar Detector
Problem for Escort Passport 8500 Radar Detector
False Laser warning when engine RPM goes over 3000.
By GerryR on Sep 01, 2007
Every time my engine rev's over 3000 rpm, I get a false laser warning. As the rpm drops below 3000, the alarm goes away. The car is 1.5 years old and this is a problem that has showed up only now after working fine for over a year.
Same Problem
Jul 18, 2008
-   I have also owned my 8500 for a couple years with no problems until yesterday when the laser started to false alarm constantly. It has been in the same vehicle (Dodge Magnum) since I bought it. I have not noticed however that it is triggered by either accelerating or slowing down. I kept unplugging it and replugging it hoping that it would re-boot properly; it worked for a couple of minutes until it started again. It is therefore unusable.-   Frenchy007
Jun 02, 2008
-   I am having the exact literal same problem as Gerry here., My Radar is about 15 months old and seems to go off in acceleration or deceleration at around 3000 rpm and I own a 2001 Nissan maxima. It happens only in Laser mode and just started happening 5 weeks ago and seems to be getting worse.
Disabling Laser would be a poor solution since it was Laser that I was most wanting to acquire when buying a radar detector. It was also Laser that almost nabbed me twice. If this Escort 8500 appears to have an exact weak spot like this,maybe than I think we should all start passing this information on to warn other buyers of this apparent trait of the Escort Passport.
How can this be solved?
-   deadcandance
May 13, 2008
-   I have the same thing. Out of no where it just started doing that. False laser readings when I accelerate.-   Guest
May 02, 2008
-   I have owned my 8500 for a couple years with no problems until a month ago. The laser started to false alarm constantly. It has been in the same vehicle (2004 F-150) since new, with no additional equipment or aftermarket accessories added. I couldn't figure out what or why it kept going off until I noticed the Laser alarm trip when I hit the throttle wide open. I found it odd, so I tried it again and again. Everytime I quickly raised the RPM's the Laser would go off. I realized that this was obviously a voltage issue. Why it just started now, I do not know. Is it better to just send it in the factory or go with a loop?-   troy777
Feb 21, 2008
-   About 6 weeks ago my unit kept going into self calibration, then about a week ago I started getting false laser warnings every time I step on the gas. I have two of these detectors, and another problem I have with both of them is when I turn on the windshield washer fluid pump the false laser goes off. Definitely seems like this unit is very sensitive to voltage changes.-   gstang46
Best Solution
posted on Sep 28, 2007
Helpful)
akielb
Rank: Apprentice
Rating: 94%, 8 votes
This is a known fault of this detector. After so much time the laser gets out of alignment and starts to give false readings. I've been searching on this myself and have found many other people complaining about the same thing. I also have my unit hardwired into my car and still have the problem.
The only DIY fix is to use the expert mode and turn off the laser.
The only true fix is to send the unit into passport, pay $60 to have it fixed.
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #2
posted on Sep 15, 2007
Helpful)
PyroMan6x9x9
Rank: Guru
Rating: 93%, 541 votes
Has any aftermarket electronics been installed recenty? Ie amplifier with sub, or do you have lots of things plugged into you cig lighter? Anyway to solve the problem you can hardwire the detector to your fuse panel on an isolated fuse to get rid of any interference, or you can purchase a device called a ground loop isolater, either way it should solve or at least reduce the problem.
Good Luck
Was this helpful?
Yes
No
Solution #3
posted on Sep 27, 2008
Very Helpful)
deadcandance
Rank: Apprentice
Rating: 91%, 7 votes
Hey guys, me again....Deadcandance..... I posted my trouble on a Satellite forum I belong to and I had a suggestion which I tried. And it worked!!!!! No manufacture returns, no cost at all, what I did was tokk it apart gently ...watch how everything comes apart so that you can reassemble again....
Start by getting a couple Q-Tips (Ear Swabs).Leave them dry so they won;t leave any residue on the diodes. Gently clean the horn, than clean/wipe the electronics board, and blow out the diffusion screen (leave the spit in your mouth). After I wiped the unit down, I didn't see any dust persay or dirt on the Q-tip but whatever I did, fixed it....
It worked for me. Took 15 minutes to do and I have been using the Radar for three months and not one false alarm in Laser mode.
Good luck...
Comments:
Sep 27, 2008
- Hi All,
I fixed my Radar, No Manufacturer help, no cost to me at all. I got advice from a forum member on a satellite forum I belong to. So what I did was I took apart the radar. Watch carefully how it comes apart so you can reassemble again after. Get a Dry Q-tip (ear swab) leave it dry so you do not end up leaving and residue on the diodes etc. Start by cleaning the horn, wipe the electronic board all over gently with the Qtip , blow ou the diffusion screen (leave the spit in your mouth). After all that I did not see a spec of dirt on the Q tip I used..there was no sign of dirt, residue but whatever I did do fixed the problem. I have been using it for three months and not one false alarm from the laser mode.
Good luck all......
Was this helpful?
Yes
No
Solution #4
posted on Jul 02, 2009
Somewhat Helpful)
imnraged
Rank: Apprentice
Rating: 75%, 1 votes
The poster above who states "Laser band is quite useless due to the fact that if it ever goes off in a true alert situation, your might as well get ready to pull over" is incorrect. There is an occasional speed trap in the same place on my way home from work. When the cops are there, they are using laser. I'm never the only car there and my 8500 ALWAYS tells me when they've lasered someone else...everytime. Keep the laser.
Was this helpful?
Yes
No
Solution #5
Somewhat Helpful)
breakpad
Rank: Apprentice
Rating: 75%, 3 votes
The cheapest and best thing is to turn the laser band off. Laser band is quite useless due to the fact that if it ever goes off in a true alert situation, your might as well get ready to pull over. It is not like with the K or Ka band where the radar signal is not concentrated and doesn't have to be directly pointed on any one car. The laser beam has to be pointed by a cop to your vehicle to get your speed reading, but that's when (and if) the detector picks it up and it is too late. Therefore, it is as good turned off as it is on. But there are not too many lasers that are in use by the highway patrol. But Escort is great for K or Ka bands, no doubt.
Was this helpful?
Yes
No
Solution #6
posted on Nov 20, 2009
Not Rated)
mysterybelow
Rank: Apprentice
Rating: 0%, 0 votes
Good news - I fixed it myself for free by removing three screws! It does NOT require re-calibrating, new capacitors, or sacrificing LASER detection capacity. All you have to do is follow the solution #3 as of now) posted above - it's that simple! It was posted by deadcandance
Was this helpful?
Yes
No
Solution #7
posted on Oct 23, 2008
Not Rated)
Ray Daytona
Rank: Apprentice
Rating: 0%, 0 votes
I would never run the unit without the laser function on, I have been in several situations where I have gotten laser hits as it was used on other vehicles in front of me. That being said, if your pretty handy with taking things apart and cleaning them, I would try that. My only concern here is that while you have stopped the false alarms, how do you know it is even now working at all? Sending the unit in for repair would be the best approach for a fix in this case, or upgrade to another manufacturers unit. I have both the 8500 and the V-1 and I an on the same V-1 (not considering ugrades) unit for 20 years. One upgrade resulted in a new unit as it added laser and Pop modes, others have been software related
Was this helpful?
Yes
No
Solution #8
posted on Jul 24, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
It needs re calibrating... send it back to manufacture
Popular Solutions for Escort Passport 8500 Radar
Questions and Unsolved Problems for Escort Passport 8500 Radar
Do you recommend Escort Passport 8500 Radar Detector?
Answer
Answer
My passport 8500 keeps showing this "service required" sign. how do I fix this?
Answer
I have an Escort Passport 8500 X50 which I have owned for apx 2 years. It now occasionally sends a... (More)
Answer
starts to calibrate for a while then goes to service required
6 Other Users Have The Same Problem - Continued
Comment by EASYLEI, posted on Dec 29, 2007
FALSE LASER ALARM FROM ACCELERATION. I HAVE MULTIPLE AUTOS...THE 4 CYL CAMRY HAS NO RPM ALARMS, BUT WHEN I DRIVE THE V8 TRUCK AND SUV, LASER ALARMS EVERYTIME I GET ON THE GAS! IT DRIVES ME CRAZY! I WILL TRY BUYING THE LOOP, HARD WIRING IS NOT AN OPTION NOR DOES IT SEEM TO WORK.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Escort Passport 8500 Radar...:
Top Radar Detector Experts
Rank: Guru Guru
Solutions: 14768
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Radar Detector Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
