Question about Linksys (WRT54GC) Router
Unbricking my WRT54GC router
Well, I think I broke it, unless you guys know differently. Got a WRT54GC yesterday as a gift. A friend of mine pointed out that some of the hacked WRT54G firmware has the ability to boost reception, so I figured it would work, and without doing any research, I flashed the firmware. Big mistake. The router still worked, but the Web interface was inaccessible, so I couldn't re-flash the firmware. So, remembering that most Linksys routers can update their firmware using TFTP, I dutifully downloaded TFTP2 and the latest revision of the firmware from the Linksys web site, flashed the firmware again, and...it's a brick. Right now it works as a passthrough, but that's it. I can't ping it, can't do anything with it. All the lights are on, and they blink occasionally, but it's dead as a doornail. I found a solution on another site for unbricking a WRT54G or 54GS, involving shorting pins 15-16 on the Intel chipset, but I opened the GC up last night and it doesn't have an Intel chipset, or at least doesn't have one similar to this one. So am I out of luck? Is there no other way to un-brick this thing?
    Genius:
  • 1,139 Answers
I know this is going to sound stupid, but what I want you to do is to press and hold the reset button until the unit reboots. The try to communicate with it. What you may have done if overwritten your primary software load. so what yo may have to do is try to get to the default software or the "bios" of this unit. I am almost certain that you corrupted that too but it is worth a try. You may end up buying a new unit if all of this fails. Here are some links that might help: http://nino.net/blogs/nino/archive/2005/06/09/744.aspx http://www.barik.net/archive/2004/12/03/220751/
Posted on Sep 04, 2007
Router keeps losing WAN conection, but led lamp is blinking...
maybe new aerial finds more wifi hot spots, mine started doing that when i changed router port forwarding. but if in doubt just press reset button for 10 secs - might need to se paper clip and look hard around router for a little hole to stick it in..
...lol
Jul 12, 2017 | ASUS RTN10 wireless router
Lie and scammer
The way to deal with this is to report it to the Police as harrassment and slander. You could even take it to court. The police know how to get things done on facebook. FB have to obey the privacy laws and stand to be also sued for allowing slanderous comments and harrassment to take place on their website.
Please rate my help++++Thanks for using FIXYA
Jun 10, 2010 | Facebook Social Network
I need to set a new pass word on my router.
OK, you need yo remove from power and press reset button, now using a browser login, using default login & password
http://www.retrevo.com/support/Linksys-WRT54GC-Wireless-Routers-manual/id/421dj081/t/2/
manual above, shows you how to do it all.
Apr 08, 2010 | Linksys (WRT54GC) Router
Linksys wireless router WRT54GC is not connecting to Internet
check by connecting directly your computer to modem, if still same, then contact ISP, might be a problem at thier end.
Mar 16, 2010 | Linksys (WRT54GC) Router
Open port 3306
Hi Friend,
Following are the steps as per u're problem:
1> By default ip address of all linksys router is 192.168.1.1.Open the internet browser & clear address bar at the top completely & type default gateway of yours computer which you are getting from router
2> Default username is blank & password is "admin".Otherwise give router password.Again if it is not working type default password which you usually give to your computers
3> Finally,you will be on router setup page;in top click on Applications & Gaming
4> Now click on port triggering,enter your desired port numbers & enable them --> Save Settings.
If u need technical help in order to do the above changes in router have a words with linksys technical suppoprt.
Dec 24, 2009 | Linksys (WRT54GC) Router
When installing my router wrt54GC v2.0 i encounter
More than likely you have a bad cable. Check or replace the cables. Its very common to have a bad connector on one or both ends.
Nov 04, 2009 | Linksys Wireless-G WRT54G Router
Does the WRT54GC allow SSL?
Yes. I don't know of any router that DOESN'T allow this.
Sep 27, 2009 | Linksys (WRT54GC) Router
Can't get a wireless connection from my Linksys WRT54GC router
I think you have the router setup to not broadcast the SSID. Go to your router settings to change this option. By not broadcasting, it enhances security for your wireless network, because it looks like there's no network. I hope this helps!
Jul 15, 2009 | Linksys (WRT54GC) Router
Making a wrt54gc wireless router work with a wet54g bridge
You shouldn't have to enter your SSID unless you have it hidden. Also, make sure you have the correct encryption set on both sides. WEP/WPA/WPA-2 for the Security type and TKIP/AES for the Encryption type. They need to match your router.
Also, you need ot make sure you are entering the correct IP/gateway/subnet mask address or have DHCP enabled.
Good luck
Jan 29, 2009 | Linksys : WET54G Wireless-G Ethernet...
4x4 linkage broke
working on the question had a friend of mine with same problem hes getting me all the part number you guys need he was able to fix his but all the parts where dealer only so give a few days and i should have sumthing for ya
Jan 01, 2009 | 1998 Jeep Cherokee
Open Questions:
Linksys (WRT54GC) Router Logo
2,295 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
