Portable dvd player when you put disc in machine it comes up with wrong disc display on screen is it the settings
It would more likely be the types of discs used. They are either of a region code not compatible with the player, contain foreign/unknown data, or they are unsupported formats. For example, if the player supports DVD-R playback, and you put a DVD-RW in, the player will generate 'wrong disc' message if the player cannot recognise the disc or the contents on it.
The disc formats/types that can be played should be outlined either on the unit itself or in the instruction manual (if you still have it). If the player shows that message even with genuine shop-bought DVDs then there is a defect within the unit, workshop attention may be required to fix it, but it could be costly.
'WRONG DISC' usually means the disc inserted is of a different region code to the player, or the wrong format (DVD-RW instead of DVD-R as exampled above). Try using different discs before going any further.
I have a portable dvd player made by Initial(IDM-7110). It tells me No Disc when there is one.
I have tried about 20 different disc, some new some used. The unit sounds like it is trying to load. Screen says LOADING. Then the screen says NO DISC. I have tried this with a full charged battery and the electrical plug in.
My portable DVD MPD850 player says "no disc" in player and will not play.
