Question about Canon PIXMA iP90 Mobile Printer
No ink on the paper
Hi all I have a problem with my new IP90 printer. I had installed the printer according to the indication on the manual and the paper comes out without any ink on it. I do not receive any error message from the printer. thank you
  • 625 Answers
Check to see that all packing materials have been removed. there may be a piece of masking tape somewhere in the paper path or printhead keeping printing from functioning.
Posted on Sep 01, 2007
SOURCE:
I have just replaced the black ink in my canon ip90 printer and there is still no black being printed? can you advise?
make sure that you have installed the black cartrillage properly ....if not simply remove it and install again ...and do rub the ink side of the cartillage on paper to make sure that it is properly working....after that check the roller through which the paper rolls and comes in contact with the cartillage
Jan 21, 2011 | Canon PIXMA iP90 Mobile Printer
Canon ip90 has error message 1300- there is no paper jam- have tried to reset- no luck -help
Hello there Hi there you can try.
Following step by step resetting canon Pixma iP90 :
  • Before resetting printer canon iP90, start with printer power off.
  • Press resume button coincide with power button.
  • While pressing power button, release resume button.
  • Press resume button 2 times and then release both button
  • Green LED indicator will blinking and then stopped blinking.
  • When the Power LED lights in green, press resume button 4 times.
  • Press power button and the printer power will off. Otherwise off, depress again power button.
  • And the turn on the printer again, your printer canon iP90 should be response as normal.
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 03, 2010 | Canon PIXMA iP90 Mobile Printer
I have purchased a ''Virtually Mint'' Canon Pixma ip90 printer however, when I try to print a document a message pops up stating ''the following ink tank is not installed: black ink tank, colour ink tank....
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
Jan 21, 2010 | Canon PIXMA iP90 Mobile Printer
This is my 3d iP90 in 18 mo. w/same problem: not dragging paper
That is a fairly fragile printer, if you pack them in luggage they put other bags on top which bends the frame of the printer so that paper can't pass thru anymore. The only repair is to replace the entire print engine which costs more than a new printer.
Oct 09, 2009 | Canon PIXMA iP90 Mobile Printer
Blinng orange light
Answer Part 1 of 2
An error has occurred in the printer. The number of flashes indicates the type of error, as outlined below. Check the cause and take appropriate action.
Two flashes: Out of paper or paper feed error
Reload the paper correctly and press the RESUME/CANCEL button.
Three flashes: Paper jam
If paper has jammed in the printer, clear the jam, reload the paper in the printer correctly and press the RESUME/CANCEL button.
See Paper Jams
Four flashes: Ink tank is not installed properly
Open the Print Head Cover and check whether an ink tank is installed. If an ink tank is installed, push the button of the ink tank, and reinstall the ink tank properly.
Five flashes: No Print Head installed, or Print Head failure
Install a Print Head.
When the error continues, contact a Canon service representative.
Eight flashes: Waste ink absorber almost full
Ink used for cleaning is absorbed in a waste ink absorber placed in the printer. Eight flashes indicate that the waste ink absorber is nearly full. Press the RESUME/CANCEL button to cancel the error so that you can continue printing.
Important
If this error occurs, replacement of the waste ink absorber and maintenance of the printer are required. Canon recommends to contact a Canon service representative as soon as possible. Once the waste ink absorber becomes completely full, it cannot be printed until the Waste ink tank is exchanged.
Nine flashes: A specified period of time has lapsed without receiving a response from a digital camera or digital video camcorder / The digital camera or digital video camcorder connected is not compatible with this printer
Sep 30, 2009 | Canon PIXMA iP90 Mobile Printer
My Canon Pixma IP90 will not print. It pushes the paper
you going to take printer in for repair.or get a new one
Jul 18, 2009 | Canon PIXMA iP90 InkJet Printer
My canon iP90 portable printer stopped recognizing the installation of the color ink tank. It keeps asking to install the color ink cartridge and won't print until the color ink cartridge is recognized
According to Canon, the if several actions did not correct the issue, it was a hardware problem. They sent me the location of the closest repair shop. I spoke to them and to do the repair is $80 + parts which my research estimated at between $50-$80, for a total cost of $130-$160 plus 10% cook county Illinois sales tax. I have ordered a new updated printer for a total of $215 plus no tax or shipping charge. I'll be taking the old printer to a location for recycling. I can't believe how disposable this equipment has become. What a waste of raw materials and energy.
Jun 03, 2009 | Canon PIXMA iP90 Mobile Printer
Canon pixma ip90 green light flash then orange light flash 4 times then back to green
Hi there SWCopiers,
Four flashes indicates 'Ink tanks installed incorrectly' or 'Printer needs repair'.
Click here for iP90 ink tank install procedure.
Click here for reset procedure.
Click here for instruction on contacting Canon Support. They have been very helpful. If it turns out that one of your ink tanks is faulty, they have replaced them at no cost in the past.
Hope this helps.
Remember: Good things come to those who Rate!!
Mike
Aug 07, 2008 | Canon PIXMA iP90 InkJet Printer
Ip 90
According to Canon, your ink cartridge has been installed incorrectly.
Feb 15, 2008 | Canon PIXMA iP90 Mobile Printer
Prints without any errors but no ink on the paper.
if you have new print head assembly and cartridges, and waited for flow, and the printer is MECHANICALLY sound (not dropped or G-force damaged), then all that is left is improper cartridge installation. You may not have the cartridges fully inserted/, or maybe they are not PROPERLY inserted. Look for a snap when in place (and no wiggle). I suspect this is your problem, because one symptom you mention, ink accumulation INSIDE the head/cartridge cradle, is VERY rare -unless the cartridge is inserted improperly. The cartridges/head assemblies have VERY good seals to prevent leakage. Unless the o-rings/seals are damaged, leakage outside the seal just does not happen at all, normally.
*New head/cartridge installs can take several hours -sometimes even a day in cold weather, for small iP90-like printers to saturate the heads -and print.
Oct 08, 2007 | Canon PIXMA iP90 Mobile Printer
Canon PIXMA iP90 Mobile Printer Logo
85 people viewed this question
Clive
Clive
old marine
old marine
Ekse
