Question about Pioneer SX-205 Receiver
Sx 311r I have an sx311r. It does not come on. The power output where my cd player is pluged in does work so I know it is getting current. Does it have an internal fuse? Thanks for any help. Rebfun
3 Suggested Answers
SOURCE:
  • 163 Answers
SOURCE: Power IC Damaged Displayed
if it displays "power IC damaged ,your CD player is as good as DEAD.
For giving it a new life ,take it to PIONEER SERVICE and get the IC replaced and any other repairs that may be needed.
Posted on Jul 25, 2008
  • 336 Answers
SOURCE: Pioneer SX-2300 powers up, but no sound.
Does the output relay click about 5 sec. after powering on? If it does check if the tape2/tape monitor is on. Check speakers and wiring. Try headphones.
There aren't any fuses for the output.
If no relay then it probably needs output transistors and a few resistors.
Posted on Dec 17, 2009
What kind of pre amp do i need to operate my parasound HCA-2205A high current power amp
Any preamp should work. A preamp goes into your system between the amp and the other components which plug into it- CD player, FM tuner, Turntable.....etc. It's takes their output signal, processes it as my be Volume, bass, treble... and then send a sufficient signal to the amp to drive the amp to power your speakers. As long as the preamp output is enough for your Amps input any will work as most will be.
Nov 02, 2014 | Audio Players & Recorders
No sound output from turntable on sx-780 receiver
do you have in connected to a phono input? be sure you haven't connected it to another input..........turntables are low-level (20ma) output, cannoit drive high-level input (200ma).........good success, meder's tv service
Dec 18, 2012 | Pioneer Sx 780 Stereo Receiver
Hi, I own a vintage Sony Model no. D-555 Discman Portable CD Player. Unfortunately, I have lost both the User's Manual and the Wall Wort (power supply) for it. The DC In Spec. on the back of the...
The current factor for this model is around 750mA but if you can get an adapter with 1Amp rating there is no harm as the model requires good current factor with the 9 Volt supply.
Make sure that the polarity is correct and you do not cross connect on the pin.
Feb 18, 2011 | Sony Audio Players & Recorders
Dec 17, 2009 | Audio Players & Recorders
Power is working face is not lighting up or
Did you try pluging the car (hard) blue remote wire into the "jack" on the back of the stereo arching it??
Oct 28, 2009 | Dual Electronics XDM6350 Car CD/ MP3...
Well my center speeker is not working but the rest are ok the speeker is ok but no sound . all the wires are pluged ...what can i do?
Do they use a jack plug the same size as a pair of headphones would? if so try plugging them into a radio or CD player to test that the speakers work, if you still dont get sound and your sure the volume and any other switches are in the correct possitions then you will know it is a fault with your speakers, if they do work then there is a fault with your computer outputting sound.
Jul 02, 2009 | Creative Labs Inspire P5800 Computer...
Cd will not eject
Try un-pluging the main power or the reset button if there is one behind the face plate. If niether one works return for a replacement.
Jun 02, 2009 | Car Audio & Video
Pioneer SX-205 Receiver Logo
464 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve Sweetleaf
Steve Sweetleaf
Ben Armstrong
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
